James
February 8, 2022, 4:29pm
1
A place for us to share new plugins in the Official Store
so you can see them all in one place with links to their release topics
James
February 8, 2022, 5:57pm
7
Backdated plugin announcements:
Dates follow standard ISO 8601 (YYYY-MM-DD)
DIE Fluid Synth
Read more - DIE Fluid Synth - Announcement Topic | 2021-05-25
Check it out in the plugin gallery
RMPro
Read more - RMPro - Announcement Topic | 2021-09-30
RMPro is an audio mastering plugin that will make your live music sound amazing by implementing it at the end of your pedal chain. RMPro optimizes any audio signal in real time adding depth, clarity, definition, presence and incredible stereo field...
Looperlative LP3 Basic
Read more - Looperlative LP3 Basic - Announcement Topic | 2021-12-23
Metal Tone
Read more - Metal Tone - Announcement Topic | 2022-01-30
James
February 23, 2022, 3:03pm
9
CollisionDrive
Read more - CollisionDrive - Announcement Topic | 2022-02-23
CollisionDrive is modeled after the Horizon Devices Precision Drive(*), a modern overdrive pedal with a built-in noise gate.
Besides the usual Volume and Drive controls, the CollisionDrive features Attack and Bright controls.
The Attack control...
James
March 3, 2022, 8:33am
10
Spectrum Analyzer
Read more - Spectrum Analyzer - Announcement Topic | 2022-03-02
James
March 16, 2022, 4:42pm
11
Level Meter
Read more - Level Meter - Announcement Topic | 2022-03-08
James
April 29, 2022, 10:08am
12
MDA Degrade & MDA Shepard
Read more - MDA Degrade & MDA Shepard - Announcement Topic | 2022-03-29
Check them out in the plugin gallery
The MDA Degrade is a signal degrader with extensive controls.
Use Quantize for bitcrushing, Rate for sample rate reduction and Integrator to reduce aliasing.
Use Non-Lin to add non-linear distortion to the signal, set Headroom to configure when the...
The MDA Shepard is a risset-tone generator.
Use it to generate an endlessly rising or falling tone and build tension like never before.
The Mode parameter has options for just hearing the tone, ring modulating the input with the tone, or mixing the...
James
April 29, 2022, 10:10am
13
TTAP
Read more - TTAP - Announcement Topic | 2022-04-21
James
April 29, 2022, 5:11pm
14
Audio to CV Pitch
Read more - Audio to CV Pitch - Announcement Topic | 2022-04-29
falkTX
January 4, 2023, 8:40pm
15
Reviving this topic, apologies for the lack of updates on this feed.
There has been quite a few plugins added to the official store, lets go through all of them at once.
VeJa Mutant
Read more - VeJa Mutant - Announcement Topic | 2022-07-22
x42 IR Convolver
Read more - x42 IR Convolver - Announcement Topic | 2022-11-22
Plugin to convolve audio signals, allowing you to load so-called Reverb Impulse Responses.
This is the stereo variant, with a dual input and output. A mono variant is also available.
This plugin uses background processing and is suitable to process...
VeJa Red Apple
Read more - VeJa Red Apple - Announcement Topic | 2022-12-13
MOD Noise Gate & MOD Advanced Noise Gate
Read more - MOD Noise Gate - Announcement Topic | 2022-12-13
The MOD Noise Gate is a streamlined, easy-to-use Noise Gate plugin which can also be found in the MOD Dwarf's and Duox's input processing settings.
There is a parameter to set which channel to apply the noise gate to: none, channel 1, channel 2 or...
MOD Convolution Loader
Read more - MOD Convolution Loader - Announcement Topic | 2022-12-22
The MOD Convolution Loader enables you to easily create custom reverb and other effects using impulse responses (IRs).
Using a very resource effective processing, it allows IRs with a length of up to 15s on the MOD Dwarf and MOD Duo X, less on the...
MOD & DoGood Sound Reverbs
Read more - MOD & DoGood Sound Reverbs - Announcement Topic | 2022-12-22
VeJa Roamer
Read more - VeJa Roamer | 2023-01-03
falkTX
January 6, 2023, 8:54pm
16
DoGood Sound Grain Silo
Read more - DoGood Sound Grain Silo | 2023-01-06
falkTX
January 23, 2023, 10:45am
17
DoGood Sound Dungeon
Read more - DoGood Sound Dungeon | 2023-01-13
The DoGood Dungeon gives you deep reverbs of extraordinary real spaces with its 28 high fidelity impulse responses (IRs).
DoGood Sound captured them using high-end equipment in two locations:
First, a medieval castle, hosting the name-giving dungeon...
DoGood Sound BM7
Read more - DoGood Sound BM7 | 2023-01-20
falkTX
February 3, 2023, 4:17pm
18
DoGood Sound 80’s Gear
Read more - DoGood Sound 80’s Gear | 2023-01-27
DoGood Sound Korea
Read more - DoGood Sound Korea | 2023-02-03
The DoGood Korea gives you a variety of reverbs from real spaces with its 19 high fidelity impulse responses (IRs).
DoGood Sound captured them using high-end equipment in several Korean locations, including the Gwangmyeong Cave, Seongnam Art Center...
falkTX
February 3, 2023, 4:19pm
19
MOD - Auto Input Selector
Read more - MOD - Auto Input Selector / Auto Output Selector | 2023-02-03
MOD - Auto Output Selector
falkTX
February 23, 2023, 7:13pm
20
Chow Centaur
Read more - Chow Centaur | 2023-02-23
falkTX
March 14, 2023, 6:40pm
21
DoGood Sound Israel
Read more - DoGood Sound Israel | 2023-02-10
DoGood Sound Paris
Read more - DoGood Sound Paris | 2023-02-17
DoGood Sound Work
Read more - DoGood Sound Work | 2023-02-24
The DoGood Work gives you a variety of unusual reverbs from real spaces with its 22 high fidelity impulse responses (IRs).
DoGood Sound captured them using high-end equipment in several work facilities, including warehouses, a construction site, a...
DoGood Sound Odd Ones
Read more - DoGood Sound Odd Ones | 2023-03-03
The DoGood Odd Ones gives you a variety of strange yet great sounding reverbs from real spaces with its 43 high fidelity impulse responses (IRs).
DoGood Sound captured them using high-end equipment in various locations, such as: train cars, an organ...
NOTE: This is the end of the DoGood Sound reverbs
falkTX
April 21, 2023, 2:39pm
22
Schrammel OJD
Read more - Schrammel OJD | 2023-04-21
The Schrammel OJD is heavily inspired by the schematics of a modern classic analog pedal.
For best sounding results put this somewhere before your guitar amp (plugin) and before reverb, delay and modulation plugins, just as you would place a real...
falkTX
April 27, 2023, 12:38pm
23
AIDA DSP - AIDA-X
Read more - AIDA-X | 2023-04-25
AIDA-X is an Amp Model Player, allowing it to load models of AI trained music gear, which you can then play through!
Its main intended use is to provide high fidelity simulations of amplifiers.
However, it is also possible to run entire signal...
falkTX
May 8, 2023, 10:47pm
24
Looperlative - LP3 One
Read more - LP3 One | 2023-05-09
falkTX
June 28, 2023, 1:10pm
25
Neural Amp Modeler
Read more - Neural Amp Modeler | 2023-06-28
The Neural Amp Modeler (NAM) is an open-source guitar software plugin that creates realistic simulations of analog gear, especially guitar amplifiers.
The plugin utilizes neural amp modeling technology, which employs neural networks and machine...
falkTX
July 10, 2023, 1:21pm
26
AIDA DSP Premium Plugins
Read more - PREMIUM PLUGINS by AIDA DSP | 2023-07-02
High quality model based on an original with volume, gain and channel control - just like the real amp.
Parameterized controls:
Volume on clean
Gain on rock, crunch, lead and metal
Modeled after the legendary Marshall JVM410H* amp head this...
