jon
                April 26, 2023, 10:08am
          In this topic are compiled all the models that are shared in the Model Sharing category of the forum.
DISCLAIMER
Product names and trademarks are the property of their respective holders that do not endorse and are not associated or affiliated with MOD Audio or MOD Community users; they were used merely to identify products whose sound was incorporated in the creation of models.
            jon
                April 26, 2023, 10:12am
              #3
          Peavey Bandit 112 Silver Stripe @itskais
            jon
                April 26, 2023, 10:15am
              #4
          Orange Tiny Terror @falkTX
            jon
                April 26, 2023, 10:19am
              #5
          JAD & Freer Glam @Teuvosick
            jon
                April 26, 2023, 10:20am
              #6
          Egnater Tweaker 40 USA @spunktsch )
    To keep things organized I’ll be posting my models in this thread and update the first post.
 [P1170812]
deerinkstudios-tw40-usa-high_LSTM-16.json  (53.7 KB)
"source":"original",
"style": "high gain",
"based": "Egnater Tweaker 40 USA",
"author": "deer ink studios",
"dataset": "mod",
"esr": 0.04859083518385887
Headrush MX5
deerinkstudios-mx5-ms30-clean.json  (32.1 KB)
"source": "MX5",
"style": "clean",
"based": "Matchless C30",
"dataset": "extended",
"esr": 0…
            jon
                April 26, 2023, 10:22am
              #7
          Wampler Velvet Fuzz @LievenDV
            jon
                April 26, 2023, 10:24am
              #8
          Wampler Sovereign Distortion @LievenDV
    [image]
Buon giorno!
I created a model of the Wampler Sovereign Distortion. (re-amped with the MOD Dwarf)
Gain: 3o’clock
Volume: 1 o’clock
Mid behavior: 1o’clock
Tone: 2o’clock
Even setting (no bright)
standerd (no boost)
device = MOD-DWARF
file_name = Absolute-Ruler
unit_type = LSTM
size = 16
 43% 215/500 [11:38<14:34,  3.07s/it]validation patience limit reached at epoch 216
 43% 215/500 [11:42<15:31,  3.27s/it]
ESR after training:  0.011576533317565918
Obsolete-Ruler-distortion-med-h…
            jon
                April 26, 2023, 10:26am
              #9
          T-Rex Mudhoney @Ken
    Hello guys,
Here is my first capture of MUDHONEY Collection which is Overdrive/Distortion pedal from T-REX EFFECTS.
MUDHONEY_COLLECTION
I have created several models with some according to parameters.
In all models, TONE and LEVEL are at 12 o’clock.
Please note: All models are captured “only drive pedal” without Amp and Cabs.
-MUDHONEY_CLEAN
GAIN is 9 o’clock. little bit drive tone without BOOST
-MUDHONEY_CLEAN_WITH_BOOST
Based on CLEAN model with BOOST switch
-MUDHONEY_CRUNCH
GAIN is…
            jon
                April 26, 2023, 10:27am
              #10
          Digitech Dod Looking Glass @Lukasz
    This is my first attempt of profiling. This take sounds the best.
Aida_LSTM-20.json  (82.1 KB)
            jon
                April 26, 2023, 10:29am
              #11
          Strymon Riverside @LievenDV
    [image]
Hi guys,
My first attempt at re-amping a pedal without mic’ing, just using the Dwarf.
I did some manual aligning because there was a brief latency/difference on the signals.
If useful, I can do different trainings and different settings.
ESR was my lowest ever.
Strymon Riverside HIGH GAIN
presence setting on the back: middle setting
 [image]
Dwarf with audio player: output 1 → input 2
 [image]
Yes my foil is STILL ON! [image]
device = MOD-DWARF
file_name = Strymon-R…
            jon
                April 26, 2023, 10:30am
              #12
          TC Electronics BLD @Ken
    Hi Guys,
Today, We would like to share very rare vintage one!
The based model is original vintage of BOOSTER+LINE DRIVER&DISTORTION from TC Electronic.
This pedal is very famous for being used by Allan Holdsworth.
BLD_COLLECTION
I have captured according some gain parameters in DIST mode.
Other parameter is almost 12 o’clock, and noise gate is almost off.
The GAIN setting values are those listed on the unit.
            jon
                April 26, 2023, 10:40am
              #13
          Ignite Amps NRR-1 @LievenDV
    [image]
I modeled a free amp VST in one of my attempts today, exploring the collab workbook
This was one of most accurate and I must say they are pretty close!
The model is based on the NRR-1
NRR-1 is a digital emulation of a three channels tube preamplifier for guitar. It has been developed to accurately model its real hardware counterpart, built for Fleshgod Apocalypse guitarist Cristiano Trionfera by Ignite Amps, back in 2009.
The NRR-1 core circuit is mainly based on a famous boutique p…
            jon
                April 26, 2023, 10:42am
              #14
          5150 VST by Vadim Taranov @LievenDV
    [image]
Demo 1
Demo 2
Buon giorno!
I trained the model for the 5150 VST by Vadim Taranov.
It emulated a Peavy 5150
I named this model after my own Heavy Metal / Thrash band Point Fifty,  because of the similar amps we use
Standard CPU usage
device = MOD-DWARF
file_name = Point50
unit_type = LSTM
size = 16
skip_connection = 1
ESR after training:  0.08176770061254501
Point-Fifty-amp-high-gain.json  (53.3 KB)
            jon
                April 26, 2023, 10:43am
              #15
          LePou LE456 @LievenDV
    [image]
Hi guys,
I modeled a classic, the LePou LE456, a VST amp which emulates an Engle Powerball amp.
High gain
500 epoch training
ESR 0.134ish
Works best with a cab IR (or amp settings) with some presence.
Fireball-amp-high-gain.json  (53.6 KB)
            jon
                April 26, 2023, 10:45am
              #16
          Ignite Emissary @LievenDV
    [image]
Diplomacy
Version 3 (3rd attempt, best result so far)
High gain amp, modelled after the free amp VST:
Ignite Emissary (STL Tones), a loud metal machine!
Standard CPU load
device = MOD-DWARF
file_name = v3
unit_type = LSTM
size = 16
skip_connection = 1
 30% 149/500 [08:02<17:49,  3.05s/it]validation patience limit reached at epoch 150
 30% 149/500 [08:07<19:08,  3.27s/it]
finished training: v3_LSTM-16
ESR after training:  0.04421577230095863
DEMO:
demo setup:
 [image]
Downl…
            jon
              #17
          Diezel Herbert @Teuvosick
            jon
                April 26, 2023, 10:58am
              #18
          Matchless C30 from Headrush MX5 @spunktsch )
 [P1170812]
"dataset": "mod",
Headrush MX5
"source": "MX5",
"style": "clean",
"esr": 0…
            jon
                April 26, 2023, 10:59am
              #19
          *5150 from Headrush MX5 @spunktsch )
 [P1170812]
"dataset": "mod",
Headrush MX5
"source": "MX5",
"style": "clean",
"esr": 0…
            jon
              #20
          Friedman Small Box from AxeFX3 @Teuvosick
    One of my fav amp blocks on AxeFX3.
I can’t tell the exact gain because it has an envelope follower modifier on this parameter: more stronger you play and the gain increase from 2,2 to 4,8, anyway these are the parameters.
IR used for my reference: Orange PPC 4x12
 [Screenshot 2023-04-10 alle 01.10.46]
small box dyna std.json  (53.6 KB)
ESR after training:  0.019518960267305374
