jon
April 26, 2023, 10:08am
1
In this topic are compiled all the models that are shared in the Model Sharing category of the forum.
DISCLAIMER
Product names and trademarks are the property of their respective holders that do not endorse and are not associated or affiliated with MOD Audio or MOD Community users; they were used merely to identify products whose sound was incorporated in the creation of models.
jon
April 26, 2023, 10:12am
3
Peavey Bandit 112 Silver Stripe
Captures amplifier with and without cabinet from @itskais
jon
April 26, 2023, 10:15am
4
Orange Tiny Terror
Model of Orange Tiny Terror amplifier edited by @falkTX
jon
April 26, 2023, 10:19am
5
JAD & Freer Glam
Amp model including 4 different captures with lead, crunch, drive, and clean made by @Teuvosick
jon
April 26, 2023, 10:20am
6
Egnater Tweaker 40 USA
High Gain model of the Egnater Tweaker 40 USA amplifier made by deer ink studios (aka @spunktsch )
To keep things organized I’ll be posting my models in this thread and update the first post.
[P1170812]
deerinkstudios-tw40-usa-high_LSTM-16.json (53.7 KB)
"source":"original",
"style": "high gain",
"based": "Egnater Tweaker 40 USA",
"author": "deer ink studios",
"dataset": "mod",
"esr": 0.04859083518385887
Headrush MX5
deerinkstudios-mx5-ms30-clean.json (32.1 KB)
"source": "MX5",
"style": "clean",
"based": "Matchless C30",
"dataset": "extended",
"esr": 0…
jon
April 26, 2023, 10:22am
7
Wampler Velvet Fuzz
Model of the Wampler Velvet Fuzz pedal made by @LievenDV
jon
April 26, 2023, 10:24am
8
Wampler Sovereign Distortion
Model of the Wampler Sovereign Distortion pedal re-amped with the MOD Dwarf made by @LievenDV
[image]
Buon giorno!
I created a model of the Wampler Sovereign Distortion. (re-amped with the MOD Dwarf)
Gain: 3o’clock
Volume: 1 o’clock
Mid behavior: 1o’clock
Tone: 2o’clock
Even setting (no bright)
standerd (no boost)
device = MOD-DWARF
file_name = Absolute-Ruler
unit_type = LSTM
size = 16
43% 215/500 [11:38<14:34, 3.07s/it]validation patience limit reached at epoch 216
43% 215/500 [11:42<15:31, 3.27s/it]
ESR after training: 0.011576533317565918
Obsolete-Ruler-distortion-med-h…
jon
April 26, 2023, 10:26am
9
T-Rex Mudhoney
Collection of model captures of the T-Rex Mudhoney overdrive pedal made by @Ken
The collections include captures with a variety of settings from clean to crunch with and without boost
Hello guys,
Here is my first capture of MUDHONEY Collection which is Overdrive/Distortion pedal from T-REX EFFECTS.
MUDHONEY_COLLECTION
I have created several models with some according to parameters.
In all models, TONE and LEVEL are at 12 o’clock.
Please note: All models are captured “only drive pedal” without Amp and Cabs.
-MUDHONEY_CLEAN
GAIN is 9 o’clock. little bit drive tone without BOOST
-MUDHONEY_CLEAN_WITH_BOOST
Based on CLEAN model with BOOST switch
-MUDHONEY_CRUNCH
GAIN is…
jon
April 26, 2023, 10:27am
10
Digitech Dod Looking Glass
Model of the Digitech Dod Looking Glass pedal made by @Lukasz
This is my first attempt of profiling. This take sounds the best.
Aida_LSTM-20.json (82.1 KB)
jon
April 26, 2023, 10:29am
11
Strymon Riverside
Model of the Strymon Riverside pedal with High Gain settings made by @LievenDV
[image]
Hi guys,
My first attempt at re-amping a pedal without mic’ing, just using the Dwarf.
I did some manual aligning because there was a brief latency/difference on the signals.
If useful, I can do different trainings and different settings.
ESR was my lowest ever.
Strymon Riverside HIGH GAIN
presence setting on the back: middle setting
[image]
Dwarf with audio player: output 1 → input 2
[image]
Yes my foil is STILL ON!
[image]
device = MOD-DWARF
file_name = Strymon-R…
jon
April 26, 2023, 10:30am
12
TC Electronics BLD
Collection of models of an original rare TC Electronics BLD pedal by @Ken
Hi Guys,
Today, We would like to share very rare vintage one!
The based model is original vintage of BOOSTER+LINE DRIVER&DISTORTION from TC Electronic.
This pedal is very famous for being used by Allan Holdsworth.
BLD_COLLECTION
I have captured according some gain parameters in DIST mode.
Other parameter is almost 12 o’clock, and noise gate is almost off.
The GAIN setting values are those listed on the unit.
jon
April 26, 2023, 10:40am
13
Ignite Amps NRR-1
Model of the Ignite Amps NRR-1 free VST amp simulator made by @LievenDV
[image]
I modeled a free amp VST in one of my attempts today, exploring the collab workbook
This was one of most accurate and I must say they are pretty close!
The model is based on the NRR-1
NRR-1 is a digital emulation of a three channels tube preamplifier for guitar. It has been developed to accurately model its real hardware counterpart, built for Fleshgod Apocalypse guitarist Cristiano Trionfera by Ignite Amps, back in 2009.
The NRR-1 core circuit is mainly based on a famous boutique p…
jon
April 26, 2023, 10:42am
14
5150 VST by Vadim Taranov
Model from 5150 VST by Vadim Taranov. This is an amp simulator plugin that emulates the famous Peavy 5150. This model was made by @LievenDV
[image]
Demo 1
Demo 2
Buon giorno!
I trained the model for the 5150 VST by Vadim Taranov.
It emulated a Peavy 5150
I named this model after my own Heavy Metal / Thrash band Point Fifty, because of the similar amps we use
Standard CPU usage
device = MOD-DWARF
file_name = Point50
unit_type = LSTM
size = 16
skip_connection = 1
ESR after training: 0.08176770061254501
Point-Fifty-amp-high-gain.json (53.3 KB)
jon
April 26, 2023, 10:43am
15
LePou LE456
Model of the free amp simulator plugin LePou LE456. This amp emulates an Engle Powerball amp.
Model made by @LievenDV
[image]
Hi guys,
I modeled a classic, the LePou LE456, a VST amp which emulates an Engle Powerball amp.
High gain
500 epoch training
ESR 0.134ish
Works best with a cab IR (or amp settings) with some presence.
Fireball-amp-high-gain.json (53.6 KB)
jon
April 26, 2023, 10:45am
16
Ignite Emissary
Model from the free High Gain amp simulator VST Ignite Emissary from @LievenDV
[image]
Diplomacy
Version 3 (3rd attempt, best result so far)
High gain amp, modelled after the free amp VST:
Ignite Emissary (STL Tones), a loud metal machine!
Standard CPU load
device = MOD-DWARF
file_name = v3
unit_type = LSTM
size = 16
skip_connection = 1
30% 149/500 [08:02<17:49, 3.05s/it]validation patience limit reached at epoch 150
30% 149/500 [08:07<19:08, 3.27s/it]
finished training: v3_LSTM-16
ESR after training: 0.04421577230095863
DEMO:
demo setup:
[image]
Downl…
jon
17
Diezel Herbert
3 models of the software amp simulator Diezel Herbert with clean, drive and lead settings from @Teuvosick
jon
April 26, 2023, 10:58am
18
Matchless C30 from Headrush MX5
Model of the Matchless C30 version for Headrush MX5 made by deer ink studios (aka @spunktsch )
[P1170812]
"dataset": "mod",
Headrush MX5
"source": "MX5",
"style": "clean",
"esr": 0…
jon
April 26, 2023, 10:59am
19
*5150 from Headrush MX5
Model of the 5150 version for Headrush MX5 made by deer ink studios (aka @spunktsch )
[P1170812]
"dataset": "mod",
Headrush MX5
"source": "MX5",
"style": "clean",
"esr": 0…
jon
20
Friedman Small Box from AxeFX3
Model of the Friedman Small Box version for AxeFX3 made by @Teuvosick
One of my fav amp blocks on AxeFX3.
I can’t tell the exact gain because it has an envelope follower modifier on this parameter: more stronger you play and the gain increase from 2,2 to 4,8, anyway these are the parameters.
IR used for my reference: Orange PPC 4x12
[Screenshot 2023-04-10 alle 01.10.46]
small box dyna std.json (53.6 KB)
ESR after training: 0.019518960267305374
