Gossiper - Plugin to say what is happening when you are looking it
It is necessary to have a parameter visible into the screen for raising notification/showing modal alert. If there isn’t any visible, Gossiper can’t gossip you. It is a limitation of Mod Dwarf. So it’s why I implemented the Assign to notify parameters, they appears to be dumb parameters (because bottle them on or off doesn’t change anything) but without them, isn’t possible to see the messages…
I understood. On the Chocolate forum topic, I remember that someone wrote a workaround to do this using other plugins. Check this part:
