Gossiper - Plugin to say what is happening when you are looking it
As you can see in the discussion Control to CV - HMI Widget popup message on the screen, I’m developing a plugin for enable to us, person that doesn’t have (yet) a Control Chain device, see what is happening when you are using another device for controlling your Mod Dwarf equipment. So, if you are using a, for instance, Chocolate Midi or another equipment like this, you can use the Gossiper for get some visual feedback that what is happening.
The ideia for using it is quite simple:
  1. You assign for a parameter Footswitch or Pot with the equipment what will send midi message;
  2. You assign some of the parameters Assign to notfy to a device and choose with page the notifications will appears in. There are four Assign to notfy parameters, so you can define four equipment pages for showing messages. On the above images, I am configuring to see the news on Page 3 - Subpage I
  3. Use the correspondent CV outputs for make your desired action, probably turn on/off a plugin or change other plugin parameter value.
And that is.
Note: The second option is necessary due a LV2 HMI limitation.
Maybe the mod team will improves and enable to showing popup messages when a parameter of a plugin is changed. When it occurs, I think that this plugin will be useless.
But while it doesn’t occurs, we can know what is happening by our favorite gossiper. :slight_smile:
What a great idea, can’t wait to try and get in configured with my Chocolate!
Hi @LievenDV. I’m happy that you are interested in. Currently the source that refers to potentiometer is quite unstable, but I think that the footswiches part are ok. I’m using it on my rehearsals :slightly_smiling_face:.
If you have Docker installed on your machine, you can easily install it with four or five commands. If you like to be an alpha tester (just like am I), please ping me that I can instruct you how do install it.
Cool idea! Looking forward to this!
I have no idea what that is
yeah testing sounds cool
Hello, all
I send a pull request for mod-plugin-builder,
i.e., I send a request to add this pedal into beta library. I’m not sure with more steps are required for it and its brother tetr4-switch been into beta category.
hi @SrMouraSilva … is there any progress towards getting these into the plugin store?
that would be more up to me now, will pay attention to some open PRs after some more neural model related stuff is handled
Hi all,
if there is anyone interested in to test this plugin, there is the compiled for mod dwarf
https://github.com/SrMouraSilva/plugins-lv2/raw/master/binaries/dwarf/gossiper.lv2.tar.gz
Remember to check the configuration steps, or else gossiper will no gossip
Edit: This plugin ia now available on Mod Beta Plugin Store
Hi, I did to try to install your gossiper.lv2 and tetr4-switch.lv2 folders in my Dwarf, unfortunately I get the message “Error adding effect” when I drag them on the PB…
I am sorry about it.
The compiled version that is present on the GitHub actually isn’t the version that I am using over my Dwarf. I don’t know, maybe the docker build image that I used to compile changed something :thinking:.
My Dwarf has some problem that I can’t connect it with my laptop over USB and the Bluetooth is also quite unstable too, so I can’t check the compiled version. But, I made a backup of the plugins and I will share with you tomorrow.
Just a question, is your dwarf using a version 1.13? The popup API needs it.
@zwabo, could you please test with this version?
~~pedal-pi-plugins.tar.gz - Google Drive
Thanks, but unfortunately same error when dragging on the PB…
Just a note. Both files has the same number version. I don’t know if after sending the new file to your device it is necessary to restart it.
Could you please confirm me that your dwarf is on the version 1.13? The popup API needs it.
I tried this.
Is it possible to change the content of the popup that appears?
I always see Footswitch n.
I can’t change it by rewriting the label.
It’s ok now, I did a re-install and it works . Thanks
Thanks for testing it.
No, isn’t possible because I didn’t implemented this functionality :sweat_smile:.
I would like to, but I need a source code of a plugin that has something similar to I learn how to do it.
Plugin has been pushed to beta just now!
This plugin is killer !!!
I have a few requests though :
  • could a footswitch trigger be triggered by a physical footswitch AND by another trigger inside the plugin ? (and this other internal trigger footswitch 1 could be assigned with midi)
    So, in this case, the physical footswith would change state as usual AND with midi ?
  • if you find a way to change the popup message, would it be possible to assign a midi expression pedal to the Pot 1 and then showing the value of this pot changing in a popup ?
    (as I asked here Expression pedal : showing percentage on the screen)
I don’t know any plugin doing this but the Looperlative LP3s. If not giving the source code for this maybe @looperlative could help with this ?
(changing the text of a popup message)
I’ve been from about 81% to about 72% CPU usage with your plugin, replacing 17 Control to CV plugins !!! Amazing !!! Thanks a lot !!! :pray: :clap:
From there
To there
