wow… beautiful!
i’ve gotta study this board, and look at Gossiper some more - this seems to imply that it serves more than just a notification or visual feedback function?
wow… beautiful!
I’ll make a post on this tread when I can :
(Not sure I’ll be as precise and clear as @SrMouraSilva !!!)
hey @SrMouraSilva I just tried the Gossiper and it seems quite handy indeed.
It would be indeed super cool if you could edit the text of the popup as @fxsimone suggested (and this may be the first time that I interact in this forum 100% as a MOD user only
). It would be awesome instead of reading there the number of the footswitch (for example), if we could write the text. My goal here would be to write the name of the effect that I’m turning on/off so more than knowing the state of the MIDI footswitch I would know also what I assigned it.
Hello, @Rom.
Thanks for your feedback
I am sorry, I am quite confusing because there is more than a year that I implemented it, but if you assign the midi expression for Pot 1, the behavior isn’t that you are expecting?
There is the source line of code that is responsible for defining the text value for Pot’s
You say there would be more than one parameter assignable for the same CV? So I suppose yes if I duplicate the “Footswitch” parameter.
Now if you are requesting to receive a specific Midi message from an Midi input, this would be great, but I don’t know how to develop using midi.
Wow! This is a pedalboard with a lot of advanced techniques. I’ll waiting for the description!
I have the same goal! I just don’t know yet how to do it
. A help for looperative or someone else from community would be great
you need to have atom ports with patch:Message type, then declare a few patch:writable properties of type atom:String.
basically the same way plugins deal with files, but instead of path type it is string type.
see LV2 Parameters as Strings - #3 by falkTX for a few links
Oh !!! Sorry, this is exactly what I was expecting ! It’s perfect ! Thanks !
Yes, I think that’s what I would like.
For example a midi controller footswitch sends multiple triggers :
But I want to have a footswitch on my Dwarf to do the Delay send ON, that reflect the state of the actual state of the effect, when it is triggered with the midi controller or with the Dwarf’s footswitch.
Actually the Assign to notfy1 doesn’t do anything when pressed ON or OFF, could it trigger the Footswitch 1 ?
It is necessary to have a parameter visible into the screen for raising notification/showing modal alert. If there isn’t any visible, Gossiper can’t gossip you. It is a limitation of Mod Dwarf. So it’s why I implemented the Assign to notify parameters, they appears to be dumb parameters (because bottle them on or off doesn’t change anything) but without them, isn’t possible to see the messages…
I understood. On the Chocolate forum topic, I remember that someone wrote a workaround to do this using other plugins. Check this part:
Yep, I get that, but does it mean this parameter should be useless ? I was hoping it can do both :
I don’t find it… I found this workaround to have both controls on the Dwarf and the midi controller, but I think with a mindi + feedback loop it’s a lot easier
So my hope reports to the solution proposed here… one day :
Thanks again, and a lot !!!
Is Gossiper available for the Mod Duo X? I cannot find it in the beta store. Or is it perhaps not compatible with the displays on the MDX?
