Beta No More? The Beta Plugins You Can't Live Without — Let's Get Them Polished and Official
Hello all,
As many of you probably already noticed, I’m trying to take a more active role in everything to do with plugins, from testing them to giving feedback and mostly trying to move some strings so new creations can move forward and not stay stuck in a limbo before being published or in the beta store (especially when missing only some “simple” things like UI, testing or documentation). A side goal of these efforts of mine is also to allow us to clean up the Beta store.
Therefore, I would like you all to speak your voice!
  • Are there any Beta plugins that you use regularly?
  • Are there any plugins in the beta store that you see as valuable for you and/or could be problem solvers?
If you answered “Yes” to at least one of these questions, I would really like you to share those plugins with me so I can start listing them.
In fact, I’ve already started creating this list. My approach to finding out which plugins could be prioritised was by filtering the most recent pedalboards shared on the Pedalboard Feed using beta plugins. I’ve gone so far as around two years back. Yet, there are a few loopholes in this system 1) some pedalboards were simply shared for troubleshooting reasons and 2) some plugins may not be so important, but have been simply inside shared pedalboards.
Please note that this post is not meant for plugin requests, not even for the plugins that have been recently shared here in the forum and are not on the beta store (those we may take a different route). My question is only directed for the plugins already available on the Beta Store.
Thanks in advance for all your help :slight_smile:
EDIT: for easier mapping, we created a Google survey. Please go there and “vote” on your plugins
:star_struck: :heart_eyes:
This is an assignment where I can help.
I will provide my list asap
Beta Plugins I use and find useful: (in order of being used/useful to me)
  • Portal Source (Falk)
  • Portal Sink(Falk)
  • bluesbreaker (Brummer)
  • record-mono (brummer)
  • record-stereo (brummer)
  • record-quad(brummer)
  • C* ChorusI - Mono chorus/flanger (MOD Team)
  • Compressor Advanced (MOD Devices)
  • Calf Deesser (Calf)
  • Calf Limiter (calf)
  • Calf Haas Stereo Enhancer (Calf)
  • rkr Analog Phaser (Rakarrack team)
  • Moog Low-Pass Filter 2 (David Robillard)
  • Record-Quad Mini (brummer)
  • GxGraphicEQ (Guitarix)
  • GxTubeTremelo (guitarix)
  • Calf Exciter (calf)
  • Calf Gate (Clf)
  • FATFROG (Brummer10)
  • Calf Sidechain Compressor (Calf)
  • rkr EQ (Rakarrack team)
  • PowerAmpImpulses (Brummer)
  • PreAmpTubes (Brummer)
  • PowerAmpTubes (Brummer)
  • PowerAmpImpulses (brummer)
  • Calf Vintage Delay (calf)
  • Cardinal FX (DISTRHO)
  • reverb-amb (David Robillard)
  • Sawtooth (David Robillard)
  • Triangle (David Robillard)
  • Calf Filter (Calf)
  • Instrument Tuner (robin gareus)
  • Wolf Shaper (Patrick Desaulniers)
Haven’t used (yet) but seem interesting enough to check with community
  • Audio Capture (Falk)
  • Bollie Delay XT (Bollie)
  • GxTubeDelay (guitarix)
  • Harmonic Exciter (Brummer)
  • Neural Record (brummer)
Great @LievenDV!
Thanks a lot for your lists and excitement.
Just a little point for clearness, some of the plugins in your list are already in the stable store. I can think quickly of two: Record-Quad Mini and the FATFROG
It would be helpful to have a current list of all beta plugins. Or to enable beta access there.
Regular use :
ALO
MidiDisplay
MrFreeze
Portal Sink/Source
PowerAmpImpulses
PreAmpTubes
PowerAmpTubes
PowerAmpImpulses
Dave Mollen’s TimeWarp
Interested in :
Gossiper
Let’s not forget:
  • pretty much all CALF’s plugins
  • Cozmic
  • Dexed
  • Harmonic Exciter
  • Midi Display
  • Mirrorz
  • Morlot Lite Mono
  • ObXd
  • Ratatouille (perhaps it will support A2 models)
  • RkR Mutromojo
  • Seq
  • Stone Phaser
  • Stone Phaser Stereo
  • Tetr4 switch
  • Timewarp
  • Xfade1to2st
I went for what the plugin story labelled as beta so that’s…odd?
Have you all plugins updated?
If you could upload an up-to-date list of beta plugins here, we could check them out and vote at our leisure without having to boot up ModAudio. :slight_smile:
Yep a list in a survey, so you could easily see these most used ?
on my side, here they are :
These aren’t even in the store :
WOW (from @Jacube)
Freezer - freeze your tone forever (from @Jacube)
I clicked updated on the plugin when it said “newer version available”
That’s right! It will also make my work in the end easier.
I will edit the first post with a Google Survey
@LievenDV, @pilal, @Abotte and @Rom, first of all thanks a lot for your shares.
I’ve updated the first post with a link for a survey:
Could you please go there and “vote” on the plugins that you’ve mentioned?
I’m sorry for the double work
I @LievenDV, let’s try a last thing before branching the issue to a new thread. Could you please uninstall and re-install those plugins? Does that fix it?
No worries, it’s done :wink:
@LievenDV I just understood now that I was wrong. Those are indeed beta plugins. I’m not sure why, but the beta label was not showing up in my case, but after removing them, it popped up again with the beta label. Sorry by leading you to think that you had an issue that you don’t.
ALO - genius idea - (audio threshold triggered looper with fixable durations) though memory issues
Dave Mollen’s Repeater (a kind of audio monosodium glutomate - incredibly versatile and makes everything sound better)
Midi Display (absolutely essential - but it would be great if someone could write a “log” version which shows timestamped history of midi messages - even if the log is only the last 10 messages)
Calf Mono-compressor (for garagy/psychobilly sound, joined with Screaming Bird + Modulay sounds amazing)
Record-quad (brummer) - unbelievably useful - I found looping live in public, I can get a pure recording of the performance from the mod, which I can then mix with a field recording
(though this can build up a large amount of data in the lv2/recordings (or whatever it is called) which you have to be careful to remove. If the mod could have some way of purging recordings from the device itself rather than via ssh that would be really useful.
(after viewing the full list)
RKR Arpie is amazing - makes the most wonderful otherwordly sounds
RKR MuTroMojo is a really brilliant wah sound
The ZAM compressor is something I really like too
