Hi I’m following the wiki but I can’t figure out how to make it work. I have the midi cable out from a Digitone II to a the midi in of the Mod Dwarf. The pedal board channel on MD is set on 2, same channel is turned on on DNII, I go into the parameter (a high pass filter parameter of an EQ pedal) click midi tab and follow the instruction. I save as instructed and turn the value knob on the DNII and it doesn’t work!
Went into its settings, went into the on/off parameter to assign it to midi, did the “click save/turn midi controller knob”. Nothing happened.
Also I don’t quite understand the purpose of the green serial cable? Some plugins have a midi cable in, leading to think that you need to put that serial midi cable in there, to be able to map some of its parameters to midi controller. Some other plugins, the don’t have that midi cable in, but then if you go in the parameter settings where you can assign to knobs, there is still a Midi tab and it prompts “click save/turn midi controller knob”. So does a pedal need a midi cable in, to be controlled by midi or not?What I am missing?
hey @Gio I guess that the problem you are facing is the mismatch on MIDI channel counting between devices. Some devices count from 0 to 15 and some other from 1 to 16.
To be honest, it’s been a while since I touch on this kind of stuff with any MOD to be sure of the exact implementation, but my fast suggestion to you is to try on the Digitone to put a channel higher than in the MOD Dwarf (for example: Digitone set to send MIDI via channel 2 and MOD Dwarf set to receive it on the channel 1) and vice versa (for example: Digitone set to send MIDI via channel 1 and MOD Dwarf set to receive it via channel 2).
I have the feeling that the first one is the way that the MOD is set, but as I told you, it’s been a while since I mess around with that and right now don’t have any MOD connected around me
Hi @jon thanks for reaching out and for the clear explanation. I’ll try it out later, although it all seems a bit crazy and very non-intuitive. How am I supposed to know all that as an average user?
I also stumbled upon a post around type A and type B trs adapter… Just to add a bit more to the confusion. Then is still my question around the green cable in the web GUI. Anyway. I’ll keep you posted.
There are only purple (audio), blue (midi) and orange (CV) cables in MOD.
Most plugins that have a midi (blue) input are either synths (receive notes) or manipulate the midi (filtering, etc) in some way.
As far as I know there are no plugins that receive CC values using a midi input. All parameters are mapped to midi using the parameter assignment settings dialog of that specific plugin instance.
I tried everything suggested @jon . And it doesn’t work.
Now I’am starting to think it can be a A/B TRS problem. I watched an unboxing of the Dwarf on YouTube and the original 3.5 Midi adapter is black, mine is grey (Got the Dwarf second hand, so it’s possible I don’t have the original). Is there any chance to purchase the original cable anywhere? Thanks
(sorry @dreamer I meant the blue/green-ish cable. Thanks for the explanation)
Don’t have my dwarf here, so cannot be more accurate, but on the bottom bar of the web gui you can find a midi button that open some kind of midi configuration sub menu
There you can get a list of detected controllers and you can individually enable or disable them
Good news ! It seams that you receive messages from your midi controller :
On Channel 15, the Control Change 120, the value 0 (if it’s not already assigned on you pedalboard)
So you should be able to assign any button on any plugin with this message. And then you should be able to move this button by changing the value of the message you send with your Digitone controller.
If you assign a on/off switch, it will be :
turned ON if you send Channel 15, the Control Change 120, the value > 64
turned OFF if you send Channel 15, the Control Change 120, the value < 64
Upon further tests, those number on the Midi display appear when no hardware Midi cable is going from the Digitone to the Dwarf… So I am not sure what to do with them. I did some test anyway, Connected the hardware midi cable, from Digitone channel 15, to Dwarf mid settings pedalboard channel 15, only to find CCs on Digitone only go as far as 119… .
I love the Dwarf but midi learn shouldn’t be such a complex issue. In any other device is 15 seconds operation. Since I don’t see lot of screams for help about this topic, the majority of other users must have figured it out.
Is there anyone with a working midi connection through cable? Would you be able to record a simple video with the phone of the process?.
Can someone at least confirms that the expected workflow is the following:
1. Connect to WebGUI
2. connect Midi out from Digitone II to Midi in Dwarf
5. Click save and turn Digitone II value knob 6. If working, turning the value knob will turn the parameter on the WebGUI*
*when connected to Midi, I noticed the parameter disappears from the Dwarf screen (Maybe is just because I can’t establish midi connection). So if I manage to connect it, but it still disappears, I wonder how I am supposed to know what I am changing when controlling that parameter from the Digitone II?
Gonna try the Type A TRS Midi cable before giving up.
there is clearly a problem here, you should need 5s to set it as wanted.
If you need to change snapshot or changing pedalboards… but as I understand, that is not that you want ! No ?
If you don’t target to change pedalboard let this to OFF
The only things you need to do are :
configure you ampero so it sends 2 CC messages on the same channel and same message number : on with the value “0” and one with the value “127”. For example, Channel 1 | CC1 | value 0 AND , Channel 1 | CC1 | value 127.
On my midi controller I can configure a single switch to alternate on sending these message on a signel switch with each press : when I 1 press it send “127”, the 2nde press sends “0”, the 3rd press send “127”…
on the Dwarf’s webUI chose any parameter you want to be assigned with midi, and just chose MIDI as you did. Then press you midi controller you’ve configured above, you should see a temporary message on the top right corner of the webUI telling you the parameter has just been assign to midi CC1 channel 1.
The problem on the MOD interface are :
as you can’t assign a parameter that has already been assigned elsewhere on the pedalboard, (that’s normal, but) if you don’t remember where it’s a mess to search every parameter already assigned… You should be :
at least tall that : this X midi message is already assigned
or better : this X midi message is already assigned to this X parameter on this X plugin
or even BETTER : this X midi message is already assigned to this X parameter on this X plugin, do you want to overwrite it ?
