Hailstorm | high gain based on EVH 5150 III 100W by @LievenDV
Ibanez TSA5TVR by @malfunction54
JMP low sensitivity Pedal Platform by @mreed707
Jad Freer Capo - Bass preamp by @mrdinsdale
EAE Halberd v2 and Longsword V4 by @mrdinsdale
Marshall JCM900 by @Rafa_Ruiz
Traynor Dark Horse by @Trilby
Victory VX Kraken Models by @lordsilly
Update - Whole bunch of CH1 models at two quite low gain levels. As before through power amp - with focus on and off - and through preamp only versions.
Victory-VX-CH1-FOff-G1-Heavy.json (81.2 KB)
Victory-VX-CH1-FOff-G4-Heavy.json (81.0 KB)
Victory-VX-CH1-FOn-G1-Heavy.json (81.4 KB)
Victory-VX-CH1-FOn-G4-Heavy.json (81.2 KB)
Victory-VX-CH1-Pre-G1-Heavy.json (81.3 KB)
Victory-VX-CH1-Pre-G4-Heavy.json (81.0 KB)
Soldano SLO by @Rafa_Ruiz
TIis time a capture of a Soldano SLO amp emulator with some eq … I was using it with my dwarf in some gigs and it was nice , so maybe can be useful for you too…
SLO Overdrive_LSTM-16-0 (1) (1).json (53.3 KB)
Bogner Ecstasy amp head
Multiple Channels of the Bogner Ecstasy Amp Head
Bogner 1_LSTM-16.json (53.3 KB)
Bogner Blue_LSTM-16.json (53.4 KB)
Bogner Green_LSTM-16.json (53.6 KB)
Bogner Plexi Red_LSTM-16.json (53.6 KB)
Bogner Plexi_LSTM-16.json (54.0 KB)
VX Kraken Ch1 through Randall V30 + SH57 by @jazzbre
I tried replicating my base amp + cabinet and I think it turned out well.
This was recorded with the exact settings I use normally when mic-ed (I didn’t exactly nail mic placement this time). I didn’t use the real input.wave but I just played weird stuff on different pickups and settings for about 5mins.
For a first and really hacky test I think it turned out pretty good, that’s why I’m sharing it here.-A
Victory_VX_Channel1_RandallV30.json (81.2 KB)
Brunetti 059 by @UnvisualStudio
Hi! I’ve done some captures from my amp and I want to share them with you:
Diezel based amp (simil Herbert) by @Teuvosick
3 captures of this amp, not the original, is like a homemade, I lost the logs and esr but under 0.03
Cheers
herbert ch2 clean.json (53.6 KB)
herbert ch2 drive.json (53.4 KB)
herbert ch2+ lead.json (53.4 KB)
Mercuriall Reaxis and Vtar Slowrunner by @Boukman
I ripped 2 of my favourite sounds from modelers.
SLowrunner.json (53.2 KB)
Ampbox Reaxis Hells kitchen lead.json (53.3 KB)
Peavey Minx 110 by @malfunction54
I recently modeled my Peavey Minx 110 (preamp section only) I’ve uploaded the model on AIDA-X Cloud
