Legacy Beta plugins: installer pedalboards - N to Z
Dear users
If you need one of the legacy beta plugins that were hidden, use the list below. Each link is a small pedalboard that installs one beta bundle (all the plugins in it).
This is the second portion of the list. The first portion is here: Legacy Beta plugins: installer pedalboards - A to M
How to install a hidden beta plugin
  1. On your unit’s web interface, open Settings > Interface and check on Show beta plugins in the Store
    Without it, the unit will not load a pedalboard with beta plugins.
  2. Find the plugin in the list below and open its installer pedalboard link.
  3. Load the pedalboard on your unit. It installs the whole bundle.
Legacy Beta plugins come as they are, with no support.
Installer pedalboards
N (2)
Installer (bundle) Plugins
neuralrecord Neural Record
nodelay No Delay Line
O (7)
Obxd Obxd
offset-swh Offset, sample-based
OK-AB-InputSelector OneKnob A/B Input Selector
OK-AB-OutputSelector OneKnob A/B Output Selector
OK-BrickwallLimiter OneKnob BrickWall Limiter
OK-DevilDistortion OneKnob Devil’s Distortion
OK-Filter OneKnob Filter
P (11)
peak-to-cc Peak To CC
phasers-swh 4 x 4 pole allpass, Auto phaser, LFO Phaser
pitch_scale-swh Higher Quality Pitch Scaler
Pitchotto Pitchotto
plate-swh Plate reverb
pointer_cast-swh Pointer cast distortion
portal Portal Sink, Portal Source
PowerAmpImpulses PowerAmpImpulses
poweramps PowerAmpTubes
PreAmpImpulses PreAmpImpulses
PreAmps PreAmpTubes
R (8)
Ratatouille Ratatouille
rate_shifter-swh Rate shifter
regrader Regrader
retro_flange-swh Retro Flanger
revdelay-swh Reverse Delay (5s max)
ringmod-swh Ringmod with LFO, Ringmod with two inputs
rkr-bad rkr AlienWah, rkr Analog Phaser, rkr Arpie, rkr Cabinet, rkr Coil Crafter, rkr CompBand, rkr Compressor, rkr Derelict, … (37 plugins)
Rumor Rumor
S (27)
samplv1 samplv1
satan_maximiser-swh Barry’s Satan Maximiser
sc1-swh SC1
sc2-swh SC2
sc3-swh SC3
sc4-swh SC4
sc_record Record-Mono, Record-Quad, Record-Stereo
se4-swh SE4
setbfree-controller setBfree MIDI controller
sfizz sfizz
shaper-swh Wave shaper
sifter-swh Signal sifter
simple_comb-swh Comb Filter
sin_cos-swh Sine + cosine oscillator
single_para-swh Single band parametric
sinus_wavewrapper-swh Sinus wavewrapper
smooth_decimate-swh Smooth Decimator
SoulForce Soul Force
split-swh Mono to Stereo splitter
stereoroute Stereo Routing
stereoswitchbox stereoswitchbox
stereoswitchbox2 Stereoswitchbox2
stone-phaser-stereo Stone phaser stereo
stone-phaser Stone phaser
surround_encoder-swh Surround matrix encoder
svf-swh State Variable Filter
system-compressor Compressor
T (22)
TAL-Dub-3 Tal-Dub-3
TAL-Filter-2 Tal-Filter-2
TAL-Filter Tal-Filter
TAL-NoiseMaker Noize Mak3r
TAL-Reverb-3 Tal-Reverb-III
TAL-Reverb Tal-Reverb
TAL-Vocoder-2 Tal-Vocoder-II
tamgamp Tamgamp, TamgampGX
tap-deesser TAP DeEsser
tap-limiter TAP Scaling Limiter
tap-pitch TAP Pitch Shifter
tap-rotspeak TAP Rotary Speaker
tap-vibrato TAP Vibrato
tape_delay-swh Tape Delay Simulation
testsignal Test Signal Generator
tetr4-switch Tetr4 switch
TheCloud TheCloud
ThePilgrim The Pilgrim
transient-swh Transient mangler
triceratops Triceratops
triple_para-swh Triple band parametric with shelves
tuna Instrument Tuner
U (1)
u_law-swh μ-Law Compressor
V (4)
valve-swh Valve saturation
valve_rect-swh Valve rectifier
Vex Vex
vynil-swh VyNil (Vinyl Effect)
W (4)
wave_terrain-swh Wave Terrain Oscillator
waves-rs Waves
wolf-shaper Wolf Shaper
Wolpertinger Wolpertinger
X (1)
xfade-swh Crossfade, Crossfade (4 outs)
Z (29)
ZamAutoSat ZamAutoSat
ZaMaximX2 ZaMaximX2
ZamDelay ZamDelay
ZamDynamicEQ ZamDynamicEQ
ZamEQ2 ZamEQ2
ZamGate ZamGate
ZamGateX2 ZamGateX2
ZamGEQ31 ZamGEQ31
ZamHeadX2 ZamHeadX2
ZamPhono ZamPhono
ZamTube ZamTube
ZaMultiComp ZaMultiComp
ZaMultiCompX2 ZaMultiCompX2
zm1-swh z-1
zwabo-cozmic COZMIC
zwabo-mirrorz MIRRORZ
zwabo-stuttter STUTTER
zwabo-toggle_2in Toggle_2IN
zwabo-xfade1to2st Xfade1to2st
zwabo-zinvert_phase Zinvert_phase
zwabo-ztoggle4 Ztoggle4
ZynAddSubFX ZynAddSubFX
ZynAlienWah ZynAlienWah
ZynChorus ZynChorus
ZynDistortion ZynDistortion
ZynDynamicFilter ZynDynamicFilter
ZynEcho ZynEcho
ZynPhaser ZynPhaser
ZynReverb ZynReverb
