Dear users
If you need one of the legacy beta plugins that were hidden, use the list below. Each link is a small pedalboard that installs one beta bundle (all the plugins in it).
This is the first portion of the list. The second portion is here: Legacy Beta plugins: installer pedalboards - N to Z
How to install a hidden beta plugin
On your unit’s web interface, open Settings > Interface and check on Show beta plugins in the Store
Without it, the unit will not load a pedalboard with beta plugins. -
Find the plugin in the list below and open its installer pedalboard link.
Load the pedalboard on your unit. It installs the whole bundle.
Legacy Beta plugins come as they are, with no support.
Installer pedalboards
0–9 (2)
| Installer (bundle) | Plugins |
| 3BandEQ | 3 Band EQ |
| 3BandSplitter | 3 Band Splitter |
A (43)
| a_law-swh | A-Law Compressor |
| advanced-compressor | Compressor Advanced |
| aether | Aether |
| AirFont320 | AirFont320 |
| Airwindows-Acceleration2 | Acceleration2 |
| Airwindows-ADClip7 | ADClip7 |
| Airwindows-Baxandall | Baxandall |
| Airwindows-Capacitor | Capacitor |
| Airwindows-Capacitor2 | Capacitor2 |
| Airwindows-Channel8 | Channel8 |
| Airwindows-ClipOnly | ClipOnly |
| Airwindows-ClipOnly2 | ClipOnly2 |
| Airwindows-Console7Buss | Console7Buss |
| Airwindows-Console7Cascade | Console7Cascade |
| Airwindows-Console7Channel | Console7Channel |
| Airwindows-Console7Crunch | Console7Crunch |
| Airwindows-DeBess | DeBess |
| Airwindows-Dyno | Dyno |
| Airwindows-EdIsDim | EdIsDim |
| Airwindows-EveryTrim | EveryTrim |
| Airwindows-Galactic | Galactic |
| Airwindows-Mackity | Mackity |
| Airwindows-MidSide | MidSide |
| Airwindows-Mojo | Mojo |
| Airwindows-MV | MV |
| Airwindows-Nikola | Nikola |
| Airwindows-PocketVerbs | PocketVerbs |
| Airwindows-Pressure5 | Pressure5 |
| Airwindows-Sidepass | Sidepass |
| Airwindows-Spiral | Spiral |
| Airwindows-StarChild | StarChild |
| Airwindows-Vibrato | Vibrato |
| alias-swh | Aliasing |
| allpass-swh | Allpass delay line, noninterpolating |
| alo | ALO |
| am_pitchshift-swh | AM pitchshifter |
| amp-swh | Simple amplifier |
| AmplitudeImposer | Amplitude Imposer |
| ams | Amplitude Modifier, AMS Advanced Envelope, AMS Amp, AMS Analog Driver - 2 Outputs, AMS Analog Driver - 4 Outputs, AMS Analog Driver - 6 Outputs, AMS Analog Memory, AMS Bitgrinder, … (57 plugins) |
| analogue_osc-swh | Analogue Oscillator |
| artyfx-bad | Della, Ducka, Masha, Panda, Satma, Vihda, Whaaa |
| audio-bridge | Audio Capture, Audio Playback |
| AVL_Drumkits_Perc | Drumkits Percussion |
B (14)
| b_overdrive | setBfree Organ Overdrive |
| b_reverb | setBfree Organ Reverb |
| b_whirl_xt | setBfree Whirl Speaker - Extended Version |
| balance | Stereo Balance Control |
| bandpass_a_iir-swh | Glame Bandpass Analog Filter |
| bandpass_iir-swh | Glame Bandpass Filter |
| bentdelay | the infamous bent delay |
| blop-bad | 16 Step Sequencer, 32 Step Sequencer, 4 Pole Resonant Low-Pass, ADSR Envelope, Amplifier, Clock Pulse, Clock Square, Control to CV Interpolator, … (16 plugins) |
| blop | Sawtooth, Square, Triangle |
| bluesbreaker | bluesbreaker |
| bode_shifter-swh | Bode frequency shifter |
| bode_shifter_cv-swh | Bode frequency shifter (CV) |
| bolliedelayxt | Bollie Delay XT |
| butterworth-swh | GLAME Butterworth Highpass, GLAME Butterworth Lowpass, Glame Butterworth X-over Filter |
C (13)
| calf-bad | Calf Bass Enhancer, Calf Compensation Delay Line, Calf Crusher, Calf Deesser, Calf Emphasis, Calf Equalizer 12 Band, Calf Equalizer 30 Band, Calf Equalizer 5 Band, … (39 plugins) |
| Cardinal | Cardinal |
| CardinalFX | Cardinal FX |
| CardinalMini | Cardinal Mini |
| carla-audiogain | Audio Gain (Mono), Audio Gain (Stereo) |
| carla-miditools | MIDI Channel A/B, MIDI Channel Filter, MIDI Channelize, MIDI Gain, MIDI Join, MIDI Split, MIDI Transpose |
| chebstortion-swh | Chebyshev distortion |
| comb-swh | Comb delay line, cubic spline interpolation, Comb delay line, linear interpolation, Comb delay line, noninterpolating |
| comb_splitter-swh | Comb Splitter |
| const-swh | Constant Signal Generator |
| convo | LV2 Convolution Mono, LV2 Convolution Mono=>Stereo, LV2 Convolution Stereo |
| crossover_dist-swh | Crossover distortion |
| CycleShifter | Cycle Shifter |
D (19)
| dc_remove-swh | DC Offset Remover |
| decay-swh | Exponential signal decay |
| decimator-swh | Decimator |
| declip-swh | Declipper |
| delay-swh | Simple delay line, cubic spline interpolation, Simple delay line, linear interpolation, Simple delay line, noninterpolating |
| delayorama-swh | Delayorama |
| dexed | Dexed |
| diode-swh | Diode Processor |
| divider-swh | Audio Divider (Suboctave Generator) |
| dj_eq-swh | DJ EQ, DJ EQ (mono) |
| dj_flanger-swh | DJ flanger |
| dm-Seq | dm-Seq |
| dm-TimeWarp | dm-TimeWarp |
| drowaudio-distortion | dRowAudio: Distortion |
| drowaudio-distortionshaper | dRowAudio: Distortion Shaper |
| drowaudio-flanger | dRowAudio: Flanger |
| drowaudio-reverb | dRowAudio: Reverb |
| drowaudio-tremolo | dRowAudio Tremolo |
| dyson_compress-swh | Dyson compressor |
E (5)
| eg-amp | Simple Amplifier |
| eg-fifths | Example Fifths |
| eg-midigate | Example MIDI Gate |
| eg-params | Example Parameters |
| ewham | the infamous ewham |
F (10)
| fabla2 | Fabla 2.0 |
| fad_delay-swh | Fractionally Addressed Delay Line |
| fast_lookahead_limiter-swh | Fast Lookahead limiter |
| FatFrog | FatFrog |
| flanger-swh | Flanger |
| fm_osc-swh | FM Oscillator |
| foldover-swh | Foldover distortion |
| fomp-bad | 4-Band Parametric Filter, CS Phaser 1, Moog High-Pass Filter 1, Moog Low-Pass Filter 1, Moog Low-Pass Filter 2, Moog Low-Pass Filter 3, Moog Low-Pass Filter 4, Pulse VCO, … (11 plugins) |
| foverdrive-swh | Fast overdrive |
| freq_tracker-swh | Frequency tracker |
G (26)
| gate-swh | Gate |
| giant_flange-swh | Giant flange |
| gong-swh | Gong model |
| gong_beater-swh | Gong beater |
| gossiper | Gossiper |
| gverb-swh | GVerb |
| gx_barkgraphiceq | GxBarkGraphicEQ |
| gx_chorus | GxChorus-Stereo |
| gx_epic | GxEpic |
| gx_graphiceq | GxGraphicEQ |
| gx_liquiddrive | GxLiquidDrive |
| gx_mbcompressor | GxMultiBandCompressor |
| gx_mbdistortion | GxMultiBandDistortion |
| gx_mbecho | GxMultiBandEcho |
| gx_mbreverb | GxMultiBandReverb |
| gx_studiopre_st | Gx Studio Preamp Stereo |
| gx_SunFace | GxSunFace |
| gx_tremolo | GxTremolo |
| gx_ultracab | GxUltraCab |
| gx_zita_rev1 | GxZita_rev1-Stereo |
| gxautowah | GxAutoWah |
| gxechocat | GxEchoCat |
| gxtubedelay | GxTubeDelay |
| gxtubetremelo | GxTubeTremelo |
| gxtubevibrato | GxTubeVibrato |
| gxtuner | GxTuner |
H (6)
| hard_limiter-swh | Hard Limiter |
| Harmonic_Exciter | Harmonic Exciter |
| harmonic_gen-swh | Harmonic generator |
| hermes_filter-swh | Hermes Filter |
| highpass_iir-swh | Glame Highpass Filter |
| hilbert-swh | Hilbert transformer |
I (4)
| impulse-swh | Non-bandlimited single-sample impulses |
| inv-swh | Inverter |
| invada-bad | Invada Early Reflection Reverb (mono in), Invada Early Reflection Reverb (sum L+R in), Invada High Pass Filter (mono), Invada High Pass Filter (stereo), Invada Input Module, Invada Low Pass Filter (mono), Invada Low Pass Filter (stereo), Invada Test Tones, … (10 plugins) |
| inverted-switchbox | Inverted-Switchbox |
K (1)
| karaoke-swh | Karaoke |
L (9)
| latency-swh | Artificial latency |
| lcr_delay-swh | L/C/R Delay |
| lookahead_limiter-swh | Lookahead limiter |
| lookahead_limiter_const-swh | Lookahead limiter (fixed latency) |
| loopor | Loopor |
| lowpass_iir-swh | Glame Lowpass Filter |
| ls_filter-swh | LS Filter |
| lsp-plugins-impulsantworten | LSP Impulse Responses Mono, LSP Impulse Responses Stereo |
| Luftikus | Luftikus |
M (52)
| MaBitcrush | MaBitcrush |
| MaFreeverb | MaFreeverb |
| MaGigaverb | MaGigaverb |
| MaPitchshift | MaPitchshift |
| master_me | master_me |
| matrix_ms_st-swh | Matrix: MS to Stereo |
| matrix_spatialiser-swh | Matrix Spatialiser |
| matrix_st_ms-swh | Matrix: Stereo to MS |
| mbeq-swh | Multiband EQ |
| midi-display | MIDI display |
| midi-inv-switchbox | MIDI Inverted SwitchBox |
| midi-switchbox | MIDI SwitchBox |
| midi-switchbox3 | MIDI SwitchBox3 |
| midi-switchbox4 | MIDI SwitchBox4 |
| mod-caps-CabinetIII | C* CabinetIII - Idealised loudspeaker cabinet emulation |
| mod-caps-ChorusI | C* ChorusI - Mono chorus/flanger |
| mod-caps-Compress | C* Compress - Mono compressor |
| mod-caps-CompressX2 | C* CompressX2 - Stereo compressor |
| mod-caps-Eq10 | C* Eq10 - 10-band equalizer |
| mod-caps-Eq10X2 | C* Eq10X2 - 10-band equalizer |
| mod-caps-Eq4p | C* Eq4p - 4-band parametric equaliser |
| mod-caps-EqFA4p | C* EqFA4p - 4-band parametric shelving equalizer |
| mod-caps-Fractal | C* Fractal - Audio stream from deterministic chaos |
| mod-caps-Narrower | C* Narrower - Stereo image width reduction |
| mod-caps-Noisegate | C* Noisegate - Attenuate noise resident in silence |
| mod-caps-Saturate | C* Saturate |
| mod-caps-Sin | C* Sin - Sine wave generator |
| mod-caps-ToneStack | C* ToneStack - Tone stack emulation |
| mod-cv-jack-detector | CV Jack Detector |
| mod-mda-Bandisto | MDA Bandisto |
| mod-mda-Combo | MDA Combo |
| mod-mda-DeEss | MDA De-ess |
| mod-mda-Delay | MDA Delay |
| mod-mda-Dither | MDA Dither |
| mod-mda-Dynamics | MDA Dynamics |
| mod-mda-Image | MDA Image |
| mod-mda-Limiter | MDA Limiter |
| mod-mda-Loudness | MDA Loudness |
| mod-mda-MultiBand | MDA MultiBand |
| mod-mda-RezFilter | MDA RezFilter |
| mod-mda-Splitter | MDA Splitter |
| mod-mda-Stereo | MDA Stereo |
| mod-mda-TalkBox | MDA TalkBox |
| mod-mda-TestTone | MDA TestTone |
| mod-mda-Tracker | MDA Tracker |
| mod-mda-Transient | MDA Transient |
| mod-mda-VocInput | MDA VocInput |
| mod-switchtrigger4 | SwitchTrigger4 |
| mod_delay-swh | Modulatable delay |
| molot-lite-mono | Molot Lite Mono |
| mrfreeze | Mr. Freeze |
| multivoice_chorus-swh | Multivoice Chorus |
