Dwarf as norns
Hi to everybody :slight_smile:
i’ll do the next question because , probably , im not getting about the total potencial of DWARF
Somebody here knows about Monome’s NORNS??
could i transform DWARF in a machine like NORNS that uses Lua script to be modified and configured to do what you need
Or to insert MaxMsp patches to create a glitch machine like a Microcosm’s Hologram machine
best !
The Dwarf is basically a Linux system on which you can run pretty much whatever you like as long as the CPU handles it.
I don’t know if Lua is installed on it by default (I doubt it), but if you can compile it yourself, I don’t see why it wouldn’t run. However you can use Python already.
I don’t know much about MaxMsp.
Oh , genius !
thanks for that response , it really makes totally sense :raised_hands:t2:
Certainly, as I did for COZMIC inspired by Soma Labs Cosmos.
Available now in the Beta store
woow really !
what store ??
MOD store ?
Yes, MOD Beta section:
Take a look here if you have not access to the Beta store:
