Dear community,
I present to you: 15 pedalboards for the MOD Dwarf designed with the latest and greatest reverb plugins; 6 “traditional” reverbs, 3 quick to use versions, and 6 augmented reverbs.
The collection delivers whatever you need in the heat of the moment; need something fast? It has you covered. Need something deep? Sure! Need something fresh and new that surely inspires you to write new riffs and songs? Also a resounding yes!
These pedalboards are a part of an upcoming “reverb special” in which we show the Dwarf’s excellent capabilities when it comes to reverb.
Similar to when we released the guitar synth pedalboards, there will once again be videos diving into the inner workings of (some of) the reverb pedalboards, so keep your eyes open for those in the new year ![]()
All pedalboards have been shared to the pedalboard feed as an early Christmas gift. Find the links to all the boards and short descriptions below. Looking forward to hearing what you think of them!
—Quick boards—
VERB:Quick Hall
Minimized controller addressings for quick operation, algorithmic hall reverb board using the Dragonfly Hall plugin.
VERB:Quick Room
Minimized controller addressings for quick operation, algorithmic room reverb board using the Dragonfly Room plugin.
VERB:Quick Plate
Minimized controller addressings for quick operation, algorithmic plate reverb board using the Dragonfly Plate plugin.
—Traditional boards—
VERB:Hall
Full controller addressings for deep editing, algorithmic hall reverb board using the Dragonfly Hall plugin.
VERB:Room
Full controller addressings for deep editing, algorithmic room reverb board using the Dragonfly Room plugin.
VERB:Plate
Full controller addressings for deep editing, algorithmic plate reverb board using the Dragonfly Plate plugin.
VERB:Shimmer
Fully addressed algorithmic shimmer reverb board using the Shiro Shiroverb plugin.
VERB:Spring
Convolution spring reverb courtesy of the MOD Convolution Reverb plugin. Comes with added controls for EQ and an optional Cabsim.
VERB:Convolution
A full collection of different kinds of convolution reverbs courtesy of the MOD Convolution Reverb plugin.
—Augmented boards—
VERB:Split
Split reverb created by combining Freaked Prefreak and Freaktail plugins. There is a chorus, tremolo and phaser in between the two parts of the reverb, opening up a world of sci-fi reverbs.
VERB:Dyna Shimmer
Dynamically modulated shimmer reverb with a resonant filter, where your playing dynamics can influence reverb decay and filter cutoff.
VERB:Rhythm Filter
Hall reverb with a rhythmically modulated resonant filter, has taptempo and subdivision controls. Also contains a bit of dynamic modulation.
VERB:Delayed Sub
Convolution reverb with a individual control over the predelay times for the dry signal, and for an octave down version of the dry signal. It is possible to add feedback to the predelay, and it is possible to switch between octave down and a chorus-like effect.
VERB:Gated Plate
It’s a plate, with a gate. Set the threshold and use your playing dynamics to open or close the gate. Play above the threshold to hear the reverb, play below the threshold to close the gate.
VERB:Momentary Hall
Similar to the VERB:Quick Hall pedalboard, but with a momentary effect on addressing, meaning that the effect is only on while the footswitch is held down.
