Starless-mc 19 - Starless 19 with multiple controllers (use V5 version)
NOTE: This is fairly untested at the moment as I have not had the time. Also the midi handling in mod-host has been rewritten to make it perform better so lots might be wrong. Only for the adventurous!
Overview
I have a version based on Starless 19 that adds the following:
  • Total rewrite of the midi handling to improve performance.
  • Map HMI, CC, CV and MIDI at the same time to a parameter.
  • Directly map midi without using learn.
  • Lists, plugin presets and snapshots can be changed by MIDI. Including direct indexing.
  • Midi buttons/switches are now supported.
  • Tap Tempo from MIDI buttons/switches.
  • NRPNs, 14 bit CCs and Notes supported.
  • Midi Macros allow a single midi message to affect multiple parameters.
  • Advanced setting to invert the midi values.
I will make a new instructions pdf file soon, use the V18 one at the moment…
Also Duo and DUOX version will be coming soon…
If anyone finds midi problems I can release a version with the old midi code…
Thanks Andy !!
Everything seams to work perfectly for my main pedalboard !
The wifi options doesn’t seam to work though… it looks a lot like the problem from Starless18 (Starless by aLabs – Development - #578 by Rom)
The file and the OS version in the webUI’s settings shows v1.13.5, is it normal ?
Hi @Rom
Can you try Release starless 19 with multiple controllers V2 · AndrewCapon/alabs-mod-custom-images · GitHub
I can’t find my wifi dongle that works with the Dwarf, and the one I just tried is not recognised so I am a bit blind.
This one is built with the correct 1.14.0.3370 source tar file though so maybe that will fix it!
I found my working wifi dongle, but it no longer works with starless, I’m really not sure what is going on. I remember I had to build the firmware for it before and install it on the dwarf but my old memory is a bit confused as the firmware folder doesn’t seem to exist anymore. Maybe @AndreaDelSignore has some info?
It’s perfect ! :folded_hands:
oh… mine is an old Cisco Linksys AE6000, it works nicely
Hello, @AndyCap.
I would like to make a little suggestion.
Maybe would you define an alternative name for your OS image. Probably a suffix or prefix would be great. Some suggestions:
  • andy-starless
  • staless-mc (from multiple controls)
I do not know if other ones have the same feeling as I have, but in the high frequency in the mod entire ecosystem is evolving, sometimes I fell lost.
I spend some days to understand that your work is a fork from starless and not a new feature into starless.
So, my suggestion is only for helping me to avoid confusion. I am sorry
And thanks for sharing your progress!
Mmm, it should have a different name, has something gone wrong…
Edit: I get http://moddwarf.local/?v=1.14.0.3370-stls19_multi_controllers_2
So the 1.14.0.3370 is the original Mod Version, stls19 is starless V19, multi_controllers_2 is the second release of the multi controller version.
Are you seeing something different or do I misunderstand?
It’s named “1.14.0.3370-stls19_multi_controllers_2” in the system informations.
I am sorry. I was talking about the topic names / descriptions into forum, not the image installed itself.
The topic name is “Starless 19 with multiple controllers”, are you saying it should be something like “Starless 19 alternative version with multiple controllers” or something like that?
I’m a bit confused :slight_smile:
Thanks @AndyCap !! here everything works too with midi. :grinning_face:
Note: only some stls19 functionalities seems missing, maybe old hmi controller?
I think I might be making a mountain out of a molehill, all because of a misunderstanding that’s just in my own head.
If you mind, I can delete the messages for avoiding polluiting the main forums topic.
But the idea would be
Starless-mc 19 - Starless 19 with multiple controllers (use V2 version)
So at least for me, when I see some topic with Starless-mc I will quickly identify that is related your custom image.
Hi @fer,
What is missing, so I can check what is going on?
No problem, I have made that change :slight_smile:
Hmi widgets. Looks it is shipped with controller from stls18
Is there a plugin that I can use to test HMI widgets?
this one:
In Mod-Ui clicking in Device>Display it says This device has no display areas for widgets
Nice thanks, maybe Andreas build stuff has changed and I have not got the new version, I will have a look tomorrow…
