Starless-mc 19 - Starless 19 with multiple controllers (use V5 version)
Hi @AndyCap
sorry but I’m late at work today.
These are the first things you need to check in order to have hmi-widgets distributed
The feature has two parts, and both have to be in your build. You can check each one.
1. mod-ui reads the drop-ins
Commit: Merge hardware descriptor drop-ins · sejerpz/mod-ui@f9d79bb · GitHub
mod-ui loads the descriptor MOD ships (/etc/mod-hardware-descriptor.json). Then it merges every *.json in /etc/mod-hardware-descriptor.d/ over it, in alphabetical order:
  • top-level keys replace the ones in the descriptor;
  • actuators are merged by uri.
To check that your mod-ui has it:
git -C mod-ui merge-base --is-ancestor f9d79bbc HEAD && echo OK
grep -n HARDWARE_DESC_DIR mod-ui/mod/settings.py
The drop-in folder comes from MOD_HARDWARE_DESC_DIR. If that is not set, it is the descriptor file name with .d in place of .json. So if your unit sets MOD_HARDWARE_DESC_FILE to another path, the folder changes too.
2. create-image copies the files into the image
Commits:
create-image installs hardware-descriptor.d/<platform>/*.json (e.g. hardware-descriptor.d/moddwarf-new/) into /etc/mod-hardware-descriptor.d/ of the image, as root, mode 644. The folder must be named exactly after the platform you pass to the script (moddwarf-new, modduox-new). If the folder is missing, the step is skipped without an error. So also check for the line Copying hardware descriptor drop-ins in the build output.
To check the generated image (the outer tar holds the root filesystem image):
mkdir /tmp/img && tar xf images/moddwarf/<image>.tar -C /tmp/img
ls /tmp/img
# mount or extract the rootfs you find there, then:
ls -l <rootfs>/etc/mod-hardware-descriptor.d/
And on the device:
ls -l /etc/mod-hardware-descriptor.d/
systemctl cat mod-ui | grep -i HARDWARE_DESC
If the files are on the device but nothing changes, then mod-ui is missing the commit in point 1, or it is reading another folder. If they are not in the image, the build is missing the commits in point 2, or the platform folder name is wrong.
Both parts are in the stls19 tag of both repos, so building from that tag is the quickest way to rule out a missing commit.
Santa Claude :slight_smile:
Ciao!
Thanks Andrea.
Hi Guys,
V3 available: Release starless 19 with multiple controllers V3 · AndrewCapon/alabs-mod-custom-images · GitHub
hopefully should fix the HMI widgets issue (it works here but you never know!)…
The new HMI is here !
I have a problem when saving my main pedalboard (around 73% of CPU usage) with the webUI :
  • the webUI disconnects
  • then, when I seen on the Dwarf that the pedalboard has been saved (the name change and there was the little click that tells the image has been generated), I reload the webUI, and the Dwarf reboots.
I have not this problem with a new and simple pedalboard.
Yesterday I had the same problem (sorry I was too tiered to retry and fill a report here), the the multi-assign of the parameters has been wiped of the saved pedalboard. Now this is okay.
I think I have your pedalboard somewhere, let me look…
A reboot is weird though!
Thanks, I didn’t see any issues saving (have not got all plugins though), it is very slow though, I’m installing the real starless 19 and will check if it is slow there…
Hi @rom, have you tried saving that pedalboard as a new pedalboard in starless19?
This pedalboard has been saved with your starless-mc 19.
This one was saved with the starless-mc 18 : 26-10-04 - optimised stutter - MOD Audio
I just wondered if you had used the real starless 19 with this pedalboard and tried to save?
Also is the auto panner new or was it always there?
The auto-panner was here since a long time ago.
I’ve installed the Starless 19, and I can save or save as without disconnection.
Edit : after reinstalling starless-mc 19, no problem anymore …
I can’t believe you can hold down a job and deliver all this great stuff in your spare time. I can barely keep up just consuming it!
My pedalboard’s loading fine and now have my midi/control assignments back.
Do you know if it’s likely that these changes will eventually get rolled back into starless - these MIDI/assign improvements make life sooo much easier and I can’t now live without them!
So it’s working now?
There is definitely something going very bad though, since V18 in fact. I need some time to work out what is going on but the backend is being swamped with crap loads of update messages in your pedalboard:
DEBUG: SetPortValue() sending midi 465, progress
I need a bit of time to work out what the hell “Progress” is!
Deleting the panner with the CV input stops this but I can’t see a “progress” param, I need to spend some time working out what is happening, I do not see this on linux, just on the Dwarf…
Hopefully at some time, it’s bit of work for me keeping up with merging the releases that keep coming!
The issues I was seeing is nothing to do with “progress” which is really “MANUAL” in the “Fade Stereo panning machine”, it seems to be issues with Safari. So that was a read herring!
What browser are you using @Rom
Might have nothing to do with @Rom’s issue but just in case - When I reinstalled this version (I had gone back to starless momentarily while you caught up) I found I was being swamped with midi messages and had to go back into settings and turn off “Enable Midi Feedback Sync” which I’m sure I had turned off originally.
Mmm, I wonder if that is getting activated somehow…
@AndyCap One minor observation - with the latest starless if you install a custom skin then the new options for Midi bindings aren’t available.
That Stereo panning machine has always act strangely : it always starts when I load the pedalboard (by default I didn’t put it on the critical path though).
If I build it on another pedalboard it doesn’t seam to come with this problem.
