I’ve never used snapshots, the way it works before the Starless image wasn’t for me.
But i had some crashes, only one time during a set because the stage was in full sun… I just turn the unit of.
Since I never use more than 80% of the CPU in my main pedalboard, so I had to put a maximum of plugins un parallele (so the CPU doesn’t wait for each plugin to compute)
Sorry, I didn’t know how it’s called in english I’ve been in a hurry.
Here is an example of all in series, each effect goes to another one in a straight line : BASS JOÃO - MOD Audio
Here is my old pedalboard where you can see the input 1 hiting multiple plugins at once (reverse, phaser, tremolo, freez, stutter…), but the sound path is made with multiple x-fade, so I can’t have a tremolo AND a reverse (for example) at the same time, but the CPU doesn’t have to wait the processing of each effect to make the sound go from left to right.
I use the portal but only with time effects like reverbs and delays, so I can’t feel the latency.
