ReMasterMedia - RMPro
hmm ok yeah, that is very weird.
maybe @acunha will know since he was involved with the creation of that part of the site. could be something related to RMPro requiring v1.11
I can`t see it as well
I’m wondering if there’s room for CPU usage optimization. It is currently the most expensive plugin, around 30% CPU usage.
I LOVE this plugin, it works brilliantly.
I think it’s worth pointing-out that it is doing a whole bunch of things all at the same time. While I assume the precise details are proprietory information, it seems like it might be doing some Neve-type EQ, Custom EQ, SSL compression, Tape?Saturation, Limiter and however the stereo width is achieved!.. some of this perhaps multiband.
No wonder it costs me 40% of the processing headroom on the DuoX. I just wish it didn’t.I am very nervous of using it in a live setting which I’d love to do, it spikes sometimes and I just won’t risk hitting that 100% mark.
Edit: Weirdly, adding a 2nd one of this plugin doesn’t seem to double the CP usage: I highly recommend that guitarists try using it before an amp as well as after it. Ditch any other EQ, pre-amp or anything. And then play with the settings. It’s glorious :smiley:
The “CPU usage” really doesn’t show an accurate depiction in general. Your DuoX has 6 CPU cores but this maximum percentage is really not like an average over all 6 of them. Typically you can add a second of any plugin and you won’t notice any, or much of, a difference in CPU load.
@Kennymester
There is a “cheap and dirty” way to accomplish this with the Filta plugin.
The “default” preset of the Filta is already the position you want (0,5). Create a new preset with the same value of 0,5. Now assign the preset list to a footswitch using the “assign all” button.
Now you have a push button that takes Filta to 0,5 every time you press :slight_smile:
I’ve been waiting for the store to open for several months now, and it never works (((how can I buy a plugin?
The store works perfectly for several months now… what is your problem exactly ?
I can’t buy the plugin, but I can’t show the full version either. ii ((( how can I do this? give me a link? or send
I can’t attach a photo, the forum writes an error, let me send it to your email
Make sure your unit is up to date, we had to change the plugin store backend details when MOD Devices went insolvent and became MOD Audio.
There should be an update indicator on the bottom-right of the web gui.
Hi
Do you have information on how to download the RMPro and make it work on the Mod dwarf? I bought it as a live mastering unit and can’t make it work as I can’t authorise the RMPro plug in.
Thanks
Cam
Hi,
Sorry bu I don’t understand this sentence. Do you mean you couldn’t install the trial plugin from the store ?
Apologies.
I can’t find a way to purchase it. I can open the demo of it when I use a pedalboard that someone has created with RMPro on it but I can find no way of authorising/or buying it.
I appreciate any help on this
No problem.
Do you know how to access the plugin store ?
https://wiki.mod.audio/wiki/MOD_Web_GUI_User_Guide#Installing_new_plugins
Hey thanks for getting back to me.
Yes, I’ve gone through the installation and have the demo version. The problem is when I try and buy the full version the MOD Audio site keeps going to the page to buy the hardware (in my case the Mod dwarf) it WON"T let me pay the 29.99 for the plug in.
Thanks again
Cam
Your website shows many commercial audio plug ins available that can be downloaded to the MOD Dwarf. I want to purchase and install the RMPro live mastering plug in but cannot seem to navigate your web pages to make this purchase. Am I missing something?
Turns out I was missing something. My Microsoft Edge Firewall settings were too intense and would not allow the http://moddwarf.local/.
Problem now solved.
What platform or device are you trying to buy it to?
Problem now solved.
