Hello everyone, a bugfix update for the 1.12 series is here - v1.12.1 aka “the second best time is now”.
This update fixes an important bug (but somehow only now discovered) where the Dwarf would crash when browsing snapshots right after boot.
It also allows to load remote pedalboards outside of the pedalboard feed, needed for something interesting that is coming soon…
Hope you enjoy
Here’s the full changelog:
add hysteresis to internal noise-gate
allow loading remote pedalboards with full URL
fix addressing multiple instances of AudioToCVPitch plugin CV ports
fix value for options sampleRate parameter (continuation of fix from 1.12.0)
handle web browser cut events on searchboxes
Dwarf specific changes:
fix device crash when browsing snapshots right after boot
Hello all!
Curious detail regarding the update, for a while (long while) my screens on the Mod Duo X have been dark. But during the update the lit up like a Xmas tree! Bur alas, after the update was finished the returned to their darkened state. This does not really bother me as long as I know the Mod works properly but I would appreciate an explanation/solution for this
Be well all.
That would just be the display brightness. You can configure it in the Duo X device settings.
On the final stage of the update process, the device-side controller firmware is updated too which lights up the screens fully while that happens.
All as expected.
Then contact support about it please, via support@mod.audio should work, @jon is the one that will assist you (in due time, everyone is busy in the office at the moment packing up the dwarfs)
How many minutes is “a few” minutes? Mine’s been going for over 15 minutes at this point. Looks like I’m going to be having the same updating problems I did before…
Since I did the update, pressing B and C gives me the snapshot selection and ot the pedalboard selection. I do not know how to change pedalboards now except via pc when connected.
Is this a bug or expected behaviour?
if expected, how do I browse pedalboards now?
Sadly, my experience with updating the Dwarf is that mine won’t. I’ve eventually gotten it to update but it always is an ordeal. Evidently, it looks like it’s going to be that way this time as well. It stays stuck in the “I’m updating now” mode but rarely completes the process.
I have a bit of an issue I was hoping this update would fix. During the previous update, my duo x became unresponsive after my laptop indicated that the update was complete. The device was still looking like it was updating and/or stuck in that mode. So I did what I know I shouldn’t have and turned it off. It came back up normally and indicated that it was on the new update. However, none of the pedalboards or anything else made the sound change. It was like it was in permanent bypass mode. I did a manual update after downloading the file. It finished properly, but still no effects. I got busy with he holidays, so today I noticed there was another update. I completed the update and it finished fine with a reboot. Still in bypass. I can’t figure out how to fix it. I also unplugged everything else except the duo x, which is plugged straight into my PA. Lights indicate a signal is being received. I also have the audio file player and the indicators show the audio file is progressing forward, but that doesn’t make any sound either. Any help would be greatly appreciated.
@Bruce_McLEAN, I would suggest you to write me at support@mod.audio.
Please include the serial number of your MOD Duo X and eventually a video showcasing the issues.
One thing and one question that quickly comes to my mind:
Do the new updates successfully install?
For sure you don’t have the Hardware Bypass on in the device settings, right?
