Release 0.13.0
Here’s the download link:
http://download.moddevices.com/releases/modduo/modduo-v0.13.0.tar
Version 0.12.2 is required, you won’t be able to update to this
release from older versions.
The biggest change in this release is on the plugin store, that now does
not do a full refresh/rescan after a single plugin change.
Instead, it updates only the relevant plugins.
This makes the update and installation of plugins much faster.
Another thing to note is that this release tarball comes encrypted.
This is not to prevent you from seeing its contents, but to ensure it’s
an official MOD image.
Here’s the changelog:
  • allow custom javascript in modguis
  • allow to use a USB stick for update instead of connecting to a PC [*]
  • show version number on controller display (Info -> Versions)
  • much faster plugin store actions (no longer rescans everything for a
    single action)
  • start plugin store with ‘stable’ option checked
  • rescan plugins after a plugin deploy from MOD-SDK
  • optimizations to local plugin search
  • optimizations to FFTW library
[*] applies to future updates
The update procedure is explained at the bottom of the releases page,
http://moddevices.com/releases.html
Great to see the new releasing rolling. Thanks, @falkTX!
It runs a lot more smoothly. Nice work!
A post was split to a new topic: Peakmeter leds / displays / accentuation
After 1 week testing this release is now considered stable.
Hi all!
I had troubles with Pitch shifting effects (the ones by the Mod Team) since I upgraded to 0.13.0:
They do not produce sound when they are on.
I Downgraded to 0.12.2 and it works with this release so this seems linked to the new release.
Hi @romi please open a new topic under ‘Bugs’ category and describe further what the issue is.
