Rom
1
Hi everyone,
I have made 3 presets with the WOW delay plugin I’m using on my main pedalboard :
- stereo
- slap-back
- single note feedback with 1/8.
This in the goal to have only 1 single plugin to make those 3 sounds and save some CPU.
But, I thought I could send a PC message to go from one to another, like snapshots. Could this comes with a future update ?
Does that not work with snapshots? If you are using the same plugin I thought it would
Rom
3
nope, because it will change the state of every plugins on the pedalboard…
Presets are exactly snapshots but at a plugin scale… and without midi !?
Ah you mean you want the presets within the plugin to change? Surely the presets are just a combination of parameters that can be stored in snapshot?
Away from Dwarf so can’t check as yet but either way has me thinking so cheers for that
Rom
5
Yes, this is exactly what I want to do, but with midi (or CV)
Yes, they are ! But I dont want to recall the parameters of all plugins just to change a preset on a single one.
Exactly. I also woud like that!
Also be able to use the same Expression Pedal on more than one parameter.
To say have it to control the Mix of Delay AND Reverb.
