PortProperty in Max/Gen~ plugin
I did some editing in a Mag/Gen~ plugin .ttl file . Ok to get switches from knobs (adding lv2:portProperty lv2:integer, lv2:toggled) , but two problems trying editing time properties:
  1. I’d like to be able to get the host/mod tempo controlling the BPM
    Here is the original port :
lv2:port [
a lv2:InputPort, lv2:ControlPort ;
lv2:index 4 ;
lv2:name “BPM” ;
lv2:symbol “BPM” ;
lv2:default 120.000000 ;
lv2:minimum 40.000000 ;
lv2:maximum 200.000000 ;
And here is what I did try without success:
lv2:port [
lv2:index 4 ;
lv2:name “BPM” ;
lv2:symbol “BPM” ;
units:unit units:bpm ;
lv2:portProperty mod:tempoRelatedDynamicScalePoints;
or this,
lv2:portProperty http://moddevices.com/ns/mod#tempoRelatedDynamicScalePoints ;
according to this post Tap tempo for Max/gen~ - #4 by falkTX
  1. I’d like to have a selector switch for the tempo divisions
lv2:index 5 ;
lv2:name “Div_L” ;
lv2:symbol “Div_L” ;
lv2:default 2.000000 ;
lv2:minimum 1.000000 ;
lv2:maximum 5.000000 ;
And the modification:
lv2:index 5 ;
lv2:name “Div_L” ;
lv2:portProperty lv2:enumeration, lv2:integer ;
lv2:scalePoint [
rdf:value 1 ;
rdfs:label “1/4” ;
rdfs:comment “Simple quarter notes.” ;
rdf:value 2 ;
rdfs:label “1/8.” ;
rdfs:comment “Triplet quarter notes.” ;
rdf:value 3 ;
rdfs:label “1/4T” ;
rdfs:comment “Simple eighth notes.” ;
rdf:value 4 ;
rdfs:label “1/8” ;
rdfs:comment “Dotted eighth notes.” ;
rdf:value 5 ;
rdfs:label “1/8T” ;
rdfs:comment “Triplet eighth notes.” ;
rdf:value 6 ;
rdfs:label “1/16” ;
rdfs:comment “Sixteenth notes.” ;
rdf:value 7 ;
rdfs:label “5tuplet” ;
rdf:value 8 ;
rdfs:label “7tuplet” ;
rdf:value 9 ;
rdfs:label “9tuplet” ;
rdf:value 10 ;
rdfs:label “11tuplet” ;
In both cases it doesn’t work.
Some scripting problems ?
Any help appreciated…
Hi @zwabo,
For the translate to Tempo functionality, I think you need to add too some prefixes:
@prefix units: http://lv2plug.in/ns/extensions/units# .
@prefix mod: http://moddevices.com/ns/mod#.
@prefix time: http://lv2plug.in/ns/ext/time#.
I manage to add this to gxtubetremolo with following code:
    a lv2:InputPort ,
        lv2:ControlPort ;
    lv2:index 2 ;
    lv2:symbol "speed" ;
    lv2:name "Speed";
    lv2:default 0.1 ;
    lv2:minimum 0.1 ;
    lv2:maximum 14.0 ;
    units:unit units:hz ;
    lv2:portProperty  mod:tapTempo , mod:tempoRelatedDynamicScalePoints;
I suppose for BPM should work aswell…
YES, cool it works. Thanks a lot.
Does anyone know if there may also be a @prefix problem for
lv2:scalePoint [
rdf:value 1 ;
rdfs:label “1/4” ;
etc… ??
Yes, typically rdf one is not defined (not to be confused with rdfs), see how other plugins with list parameters do it.
You are very much welcome (and appreciated) to edit the MOD wiki entry on this.
Ok, thanks for your help, everything is fine for me now.
I did an edit to the Max gen~ - MOD Wiki
That’s the first time I did this so…let me know if it seems ok for you.
And I just added a tuto-video here :slight_smile:
enjoy
