Hi there,
Any idea why not all the buttons and functions of the LP3 are assignable to “Multi button to CV” device? Some of them are but the most important like “rec”, “play/stop”, “erase” or “reverse” are not. I want to use the MOD footswitch to operate LP3 and I need the switches to have multiple functions like most of the loopers (for example, “play/stop” on single press and “erase” on long press of the same switch). The idea is not wasting all the switches for looper only. Thanx for any advice.
I might be wrong, but you can achieve that behavior with the LOOP control. Take a look at the documentation, maybe the plugin already suits your needs.
There has been some discussion of this limitation at Looper -> ONE switch
