This should be exactly the other way around.
Could be … I am not close to my DUO at the moment.
I only wanted to suggest to try another subnet.
But, falkTX, you’re the man with hands on these things so if you think this will not help the OP’s issue, I apologize for my interruption …
I can’t access 192.168.51.1 or 192.168.50.1 with http or ping. Yet if I do “System->System upgrade” the Mod disk will mount on my PC (AVLinux 2020.5.10), so I know the USB connection works. I used this method to update to 1.9.2.1617.
do you get anything in dmesg when the device boots?
maybe it is just some network autoc-onfiguration that is not happening.
My connection problem has been traced to a bad USB plug which only works part of the time (old laptop). On a different USB plug (new laptop) I’m able to connect with http.
@varpa Glad to hear that you managed to find the problem!
Just for reference, another issue sometimes is for laptops which the power management configuration will turn off the USB port too eagerly. This might cause the connection to behave erratically.
Typically this shouldn’t happen with the factory configuration but it’s possible to tweak the power management parameters and end up in a bad situation. So might help double checking that as well.
Some good news.
After getting my hands on one of these Duo units that did not want to use the new mainline kernel, now have a fix.
I just updated the tarball that contains the factory-reset script at https://wiki.moddevices.com/wiki/Troubleshooting_Reinstall_Duo#MOD_Duo_Factory_Reset
(note the v2 in the filename)
Then on top of it, as 2nd step, the full factory reset image is updated too, now being v1.9.2.1673.tar, as per
We will release a v1.9.3 update that contains this fix ASAP, we are just finalizing a few other details.
Yay! I can confirm the updated factory reset procedure works. My device is running 1.9.2 on kernel 5.4.38 now. Awesome job, @falkTX, thank you!
Thanks for the confirmation!
I just updated the nand-convert-image and livesuit links on the wiki (with today’s date in the filename, 20201028)
All methods confirmed to work on this unit that did not previously.
Awesome, thank you again for all the time and effort you’re putting in this!
Hi guys, I would like to update my MOD to the latest version. I have the Kickstarter version of MOD DUO. As I understand it on the forum, there were problems with updating the Nand or kernel, which would require a manual update that I never did, I don’t really understand about that. So, in case my system is out of date, I would like to update my system in a safe way. What should I do?
System:
Unit: MOD Duo
Build Date: 2020 Dec 02 17:25:52
OS Version: 1.9.3.1775
Kernel:
Machine: armv7l
Release: 3.4.104-rt139-modduo
Version: # 32 SMP PREEMPT RT Wed Dec 2 17:23:36 UTC 2020
First you should backup your data to a usb stick, there are options for that on the advanced settings section of the web gui.
Done that, follow the steps in Troubleshooting Reinstall Duo - MOD Wiki
Basically you are going to do an update in 2 steps. 1st one to fully reset the nand flash to the new format, then install the regular factory image.
Do not stop half way through, as the first step fully wipes the nand flash.
It worked, thank you.
Just adding this post to confirm that MOD DUO “mainline” reset instructions for Mac OS ( Troubleshooting Reinstall via CommandLine - MOD Wiki) Still work as of September 2026, but with a couple of notes.
- It initially proved problematic with my M4 Mac Mini, ended up using my i5 iMac to complete it.
- The mainline v2 Factory Reset did not work, I think i found that one first when searching, so don’t use that one.
- After the mainline v3 reset I ran the 13.4.3 Factory reset image Factory (Reset Images - MOD Wiki)
- Then the latest update from: (Releases - MOD Wiki)
Hopefully helpful for any other Mac owners that find a MOD DUO that still runs the 3.4 Kernel!
