I already gave some feedbacks about the LP3 plugin but after a few months working on it, I notice some other stuffs. Here’s a list of all of the observations that I can make. Sorry for repeating some things, I just told myself a complete recap would be more usefull for you guys.
1 - The most important commands that, in my opinion, are missing for live looping, are 3 separate « start/stop » buttons (for track 1, track 2 and both tracks at the same time)
2 - Another things that can make a big difference would be a mode that allows the audio signal to trigger the loop recording (like the ALO looper)
3 - An issue I encountered using two LP3 instances connected to each others. (the first beeing used in self-sync mode with the looper number set to 1. It sends midi to the second instance, in midi sync mode with the looper number set to 2.
The looper 2 seems perfectly synced to the tempo of the looper 1, but :
-When I stop and restart the looper 1, the phrase is played from its beggining (wich is good).
-When I do the same with the looper 2, the phrase seems to keep turning like it’s just muted. It stays synced with the first beat of the looper 1 when it was playing for the first time.
In other words, the bpm stays the same for both loopers but it seems to stop for the first one and keep turning for the other. So it can’t stay synced.
I suppose the solution would be to stop the midi bpm information sending by the first LP3 to the second one when its phrase (track1 of the self-synced looper) is not playing.
4 - When I use the start/stop command to relaunch a phrase, the very beggining of it seems like cut. Because of this sort of “fade in” effect, we don’t ear the first beat of the phrase before it reappears at its second cycle.
I think I’ve said everything and I hope my writing is understandable. I’m french and I don’t often express myself in english. Of course, I’m not certain, that I use this plugin correctly at 100%, so I guess I can be responsible of some of the issues I met.
My goal is to make an all in one live looping pedalboard for guitar, keyboard and voice. Even if I haven’t reach this yet, I’m getting more an more close and I have to say I really enjoy working on it with the Dwarf and the tonnes of things I learn thanks to the forum. So thanks a lot to the Mod team and to the users that make their contribution.
Thank you so much for the nice words. When you do reach your goal please share a couple of videos of your setup with us
Now, on the feedback…
I’m not the best and most experient looper user, I will try soon to spend some time with the LP3 hoping to fill a bit this gap of mine. So I can’t really give you accurate feedback.
Anyway, maybe it’s worth ping here the developer himself (@looperlative) so he can give you some better feedback.
I have mixed feelings about this one. I added this feature to the LP1 a long time ago and then never put it back in when I upgraded to the 2.x line of code. I received no requests from anybody to put it back in. I’ll consider it, but I’ve never considered this the best way to start recording because you can’t stop recording in the same way. Seems to me that consistency in starting and stopping methods are valuable.
This isn’t a bug but a design choice that I pulled from my original loopers. I recently made a change in behavior on my hardware loopers. So, I can make the same change in behavior here.
@jon, @looperlative, Thanks to both of you for responding so quickly.
For sure ! I’ll share all the progress I’ll make on this project.
That would be terrific. In fact it would make my third observation kind of useless as I’ve been using two loopers to create that “one start button per phrase” thing by myself.
I think I’m just used to play with this feature on my old boss RC50 looper but I guess it is just a habit I can break. I will trust your experience on this point.
Thank you, let me know if a recording of my pedalboard, using the start/stop button, can help you.
Hi there! Perhaps a stupid question, but I don’t see Looperlative in the list of plugins in the online sandbox (I just wanted to have a peek while I’m away from my gear). So, is this because Looperlative is only available for the hardware Dwarf, or am I simply not looking under the right stone? @looperlative, @jon
It’s already available on the MOD Duo X as well, yet you need the 1.12 for unlock it’s full potential (and that is still in RC stage).
Not all the plugins are available on try.moddevices.com and the reason for that is because that is mostly meant to get familiar with the platform and the workflow. I’m not even sure if any of the paid plugins is there (I’m really not sure and didn’t check it, so bare with me if I’m totally wrong)
Is there a way to make reverse function set always ON? I mean after recordinga loop I do not want to turn on reverse function, I would like it to be turned ON.
