It’s not really a “focus”. A lot of features and plugins were offered on the crowdfunding campaigns of the MOD Dwarf that are not yet available for it. We are a small team and there is no “MOD Dwarf team” and “MOD DuoX team” so, it’s a matter of timing when both devices required special attention. Common…1.12 is the number after 1.11, so that means that we will make it available for the MOD DuoX in the next version. Another option would be to hold on to the MOD Dwarf so we also had the DuoX versions ready…in what would this be beneficial? This way we can even have a more controlled test and then place all the improvements in the next release for all the devices.
I think what they are trying to say indirectly is that the plugin would still be useful even without the new integrated features of v1.11+Dwarf.
Which would be quite correct.
We will try to make the plugin available for the other units soon.
I still have to say that it helps the development and testing to have 1 single version to focus on. Once we get the modgui integration complete and known bugs fixed, we will push for Duo and Duo X builds. It is up to the plugin author to make the final decision though.
I’ll have a word with Bob
I can’t manage to record synced to the host bpm, like I do with ALO looper. Hope it will be explained in the future documentation. If anybody knows how to do that please tell me!
It sounds resonable.
Thanks for the information about TTAP. I bought it right away. It is a great and very mighty PlugIn. I love it already, although I don not understand all of it.
I just released my first track using TTAP - track 2 on this album. There are three instances of it on the board I used
Hi everybody !
I just purchased the lp3 basic and gave it a first try in selfsync mode. I love it !
The 2 tracks/ 2phrases ergonomy is almost perfect for my needs.
The only fonctions that I would like but didn’t find are an « all strat/stop » button and a « trigger mode » to start the recording of the first phrase at the very beggining of the first note.
Do you think this type of improvments can be add to this plugin ?
Thank you a lot for all the work you do.
I just bought the TTAP. Very nice first impressions!
I was looking for more info on this. There is a manual of K-Devices Phoenix series of plug-ins (of which TTAP is a part of). The MOD version of the TTAP has a slightly different layout: basically, our top row of controllers is moved to the middle of the version in the manual. But it looks pretty much the same.
I have yet to check it out myself. Here is the link.
If you like K-Devices, there us the WOV plugin as well.
I’m hoping their modulators plugins eventually get ported in
I’m trying to run a midi keyboard through the looperlative into the dexed… and not getting any midi signal to make it through through the looperlative… also tried with a couple other synths from the generators category of pedals. They work fine when going around the looperlative, nothing when going through it. I’ve messed around with the midi port options in both the looperlative settings as well as the GUI. Am I missing something obvious??
Edit: I just moved it to later in the chain and put the post-generator audio out into it rather than midi to loop that channel, but I feel like I actually want the midi going through it for some purposes…
there is zero reason why a midi signal needs to go through looperlative.
afaik the midi port output in there is for having a a few looperlatives synced with one another.
Do you want to play MIDI sequences to the dexed with the LP3 (audio looper) or just pass the signal from the LP3 MIDI signal to the dexed?
This is not possible with the LP3, for this you would need a MIDI recorder or a sequencer with a MIDI input which are - currently - not yet available for the mod.
I hope that something like this will come.
Can this looper be set up to start recording at the beginning of the next measure (synced with the device) a loop of a predefined length (in the way the ALO looper does it)? I messed around with the trial version a bit but couldn’t find an obvious way to do this, and I haven’t tried really hard because the ALO looper exists. I wouldn’t mind ‘upgrading’ to the Looperlative plugin - especially because the perpetual beta status of ALO is slightly concerning - but the traditional ‘guitar stompbox looper’ workflow isn’t really what I’m looking for.
I also can not sync to host or to midi… maybe a bug?
Forgive my ignorance, new to midi here. Bought a soft step 2 just for this reason and have been playing around with the LP3 and unless I missed something, can’t seem to figure out how to have the loops fade rather than just stopping. Can anyone point out what I’m assuming is something really simple I’m missing? Really looking forward to that PDF
PDF is already there, open the plugin info and click on “see documentation” button.
Thanks for the heads up. I hadn’t upgraded the plug in so wasn’t seeing the addition of the PDF. Much appreciated.
The documentation explains the buttons and functions but I still don’t know how to record synced to the global tempo, like I did with ALO looper. Do I have to wait a whole bar? A beat? Does it start recording when sound is detected?
I’d appreciate if anybody can explain.
Both of these work on my Linux test system. I’ll have to try cabling my Dwarf for this and see if it works there. MIDI sync should be enabled through an unseen connection in the Dwarf. The host sync is based on host clock provided to the LP3. @falkTX can comment on how the host timing is established.
