Wouw man I am blown away by all your knowledge on this forum. man amazing!
I do like to work with loopers and my oldtime favourit Looper is and will be the Boomerang Phase Sampler III. Although it sounds very strange, i have never had the opportunity to use one. by all have researched on this device / and seen it working . It has the most valuable tools for me. Main one is to record loops out of sync and create true ambient flow music - this with my didgeridoo, singing bowls, koshi chimes etc. Ofcourse when using my guitar / saxophone etc being in sync with a rhythm box is essential but with my Deep Sound Sessions being of sync and able to flow record the loops is essential.
I by no means have any coding qualities etc at all, yet I wise this shared experience and view is of some use. But perhaps you guys get inspired by this Ultimate phase looper - Boomerang Phase III looper.
Hi all,
I’ve been working on a new audio looper that synchronises with global BPM on the Duo - basically I need something that can sync multiple guitar loops to a click track with a live drummer.
The result is ALO. I’m using the x42 Step Sequencer to generate the click track:
each alo is a multi-track looper… up to six loops per instance. but yes, you could run 2 or more instances and they should (mostly) sync… there is one ‘phrase start’ per alo
Biggest problem i found with the boss Smaller pedals is that they have a lot of tone suck, and they don’t have Midi input for quantization, you have to always put the clicktrack on.
