This is the pedalboard I’m willing to use in a live gig with my Strat SSS.
Unfortunately I think Mutant amp has a little bug in volume management. Be careful when loading this pedalboard, start with a very low volume in order to avoid gain spikes.
1.CRUNCH
2.RHYTHM
3.HARD
4.LEAD
5.CLEAN
6.CRUNCH LEAD
7.RHYTHM LEAD
8.CHORUS
As usual, set the input level so that red led is barely visible. Then select first your preferred IR and then change low pass filter settings. If you’re not satisfied still, change settings of the yellow eq.
