VeJa - Mutant
Hi! I tested quite extensively the Mutant in past weeks and I think it is the best amp in the store so far. Great job @Jan !!!
Unfortunately I think it has a two little bugs in volume management.
Bug 1: When you load the pedalboard, 1.CRUNCH is selected and the the volume is very high. The scene does not use the drive channel. Then if you select a scene with drive channel on, let’s say 4.LEAD, the volume goes at normal level and the initial issue disappears.
Bug 2: When I move from 4.LEAD to 5.CLEAN or 8.CHORUS there’s a nasty volume spike. I’ve already experienced this kind of problem with other amps and I don’t know if it is strictly related to Mutant or to MOD platform in general.
Here’s my under testing pedalboard.
I’d like to know from Duo X users what’s the CPU usage on their side. On Dwarf is around 70-78% with buffer size 256.
