there is a workaround in place for the issue I mentioned above, starting in 1.13.
see Release 1.13.0 (Dwarf only, beta testing)
@falkTX I have only seen this issue with the USB cable plugged and the UI running on a browser. This suggests that there may be something in a driver/module related to USB. I don’t know if this setup can trigger the Neon issue that you’ve seen, but I don’t have any glitches when the USB is disconnected.
it depends on the plugins in use I think, because some will keep events flowing in both directions while web gui is open.
is there a difference between USB connected but no web gui open vs with it visible?
These are the results that I’m seeing:
- Never fails when no USB is connected
- Fails but not often when USB connected and no web GUI. (Got a click just plugging USB in while running)
- Fails most frequently when USB is connected and web GUI is open.
Also, the LP3 undo button seems to be one mechanism of triggering it. I’m going to look into that. I do use the work queue to handle the file access which should be fine, but maybe there is something else that contributes to the overall problem.
UPDATE: There is no significant work happening in the audio thread during an undo. All the slow work is done via schedule_work().
Ok.
I just discovered this thread>
I have big issue with some of my pedalboards and CPU use.
When I load the pedalboard cpu use is at 50% and 1h later it raise at 75% sometimes more with no effect on, only 2 compressors and Guitarix Amp.
I suspected the convolution reveb to be faulty wich is true because without it the cpu use is more stable but I alway notice some cpu drops.
But I realize that I have never suspected the usb connection.
I will dig in this direction but the problem is how to see the cpu usage without the web interface?
I think that an integrated cpu gauge is really missing on Mod devices.
Thanks.
Yeah it would be usefull to have an integrted cpu meter.
That’s curious to see that in 2018 some user had the same issue I have concerning the CPU usage growing without doing anything when I load a convolution reverb.
