Hi! I’m interested in developing control chain devices and I think CV input and output ports for the Dwarf would be a useful addition. I haven’t seen any documentation specific to CV operation or messages beyond using a CV port in a pedalboard. Is it possible for a CC device to enumerate a CV port? Is this something that happens at the Linux kernel level? Where would I get started with CV at this level? Thanks, and look forward to what comes of this
I’m not 100% sure of this (maybe @falkTX or @jesse can give me a little help here), but I believe that the implementation of the Control Chain protocol doesn’t allow a direct connection as CV on the MOD Dwarf. I believe that you may have a way to somehow code the conversion on a Control Chain device in order to get it working. So you won’t be able to get it in the MOD Dwarf as a CV input, as you can do on the MOD DuoX
That’s kind of what I figured. My assumption was that I’d have to read the CV voltage from an input on my custom device and then pass that value on to through CC protocol. But then I was wondering who would consume that value. I imagine some virtual CV port, but maybe that has yet to be implemented. Or perhaps that’s something I’d have to implement myself.
Exactly. Although I can understand how cool it would be to have some sort of “direct line”.
You would need to map it as any other Control Chain device. Like we explain here.
Thanks! I think that answers all of my high-level questions! I had read that you could use CV plugins without having any hardware CV ports, but hadn’t gone through the steps to do so until I read through your link. I’m sure there will be more questions later, but that was certainly helpful!
Indeed, but it’s only internally. Just the MOD DuoX (as it has CV ins and outs) allows them to be connected externally.
