Ibanez TSA5TVR
I profiled my little Ibanez 5W tube amp. When paired with a Jensen C8R IR, it sounds reasonably close to the real thing. This profile is clean, but I recorded on max volume. It is fairly easy to push into breakup. Treble at 10 o’clock, bass at 2 o’clock, built-in spring reverb off, and built-in TubeScreamer circuit off.
Ibanez TSA5TVR.json (171.3 KB)
Thanks.for sharing.
I think I have that IR as well so I’ll be chacking that out soon! :smiley:
I also own this amp and your profile is really great! Thanks!
Glad you like it! It turned out nice enough that it has me wanting to redo my Hughes & Kettner Deluxe 20
What will you be doing differently than the first time?
I’d like to know your finding because if they made a difference, I can add them to my “best practices” article New Blogpost: AIDA-X modeling best practices
I think it was my amp output. I made the HK D20 model fairly clean, and it is much harder to push into distortion.
