Gen~ to MOD, build system seems broken
This is huge! Thank you so much! Very excited for I try these out. Also big aplause for including Faust here as well :raised_hands::raised_hands:
hi Falk,
doesn’t work for me:
  • I’m on win 10 using firefox
  • dwarf is connected via USB
    steps:
  • upload gen_exported.h and gen_exported.cpp
  • press ā€˜build’
    …build runs nicely, but throws ā€˜error 2’
  • press ā€˜upload’
    …I get ā€˜no plugins found in bundle’
am I missing something?
cheers R
Hi @falkTX ,
same problem of @rbrt here… also a stupid gen~ in1 to out1 plugin fails to compile. Error 2 at the end of the building and then no plugins found in bundle. here the building log:
/usr/bin/make -j1 O=/root/mod-workdir/modduo-new HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
make[1]: Entering directory '/root/mod-workdir/modduo-new/build/buildroot-2016.02'
GEN /root/mod-workdir/modduo-new/Makefile
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/root/mod-workdir/modduo-new/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/root/mod-workdir/modduo-new/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/root/mod-workdir/modduo-new/build/buildroot-config/tristate.config BR2_CONFIG=/root/mod-workdir/modduo-new/.config BR2_EXTERNAL=/root/mod-plugin-builder/plugins-dep HOST_GCC_VERSION="12" SKIP_LEGACY= /root/mod-workdir/modduo-new/build/buildroot-config/conf --silentoldconfig Config.in
make[1]: Leaving directory '/root/mod-workdir/modduo-new/build/buildroot-2016.02'
>>> tmp8owi0uji b236792fa2bd4c3173c7182afe3e358a77e58df1 Downloading
Doing full clone
Cloning into bare repository 'tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1'...
>>> tmp8owi0uji b236792fa2bd4c3173c7182afe3e358a77e58df1 Extracting
gzip -d -c /root/mod-workdir/download/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1.tar.gz | tar --strip-components=1 -C /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1 -xf -
>>> tmp8owi0uji b236792fa2bd4c3173c7182afe3e358a77e58df1 Patching
>>> tmp8owi0uji b236792fa2bd4c3173c7182afe3e358a77e58df1 Configuring
rmdir /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/source/dpf
ln -s /root/dpf /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/source/dpf
cp /root/mod-plugin-builder/plugins-dep/../plugins/package/tmp8owi0uji//gen_exported.cpp /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/plugin/
cp /root/mod-plugin-builder/plugins-dep/../plugins/package/tmp8owi0uji//gen_exported.h /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/plugin/
env MAX_GEN_AUTOMATED=1 MAX_GEN_NAME="_test" MAX_GEN_BRAND="_fc" MAX_GEN_SYMBOL="test" MAX_GEN_DESCRIPTION="MAX gen~ based plugin, automatically generated via mod-cloud-builder" MAX_GEN_LV2_CATEGORY="lv2:ModulatorPlugin" /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/setup.sh
>>> tmp8owi0uji b236792fa2bd4c3173c7182afe3e358a77e58df1 Building
PATH="/root/mod-workdir/modduo-new/host/bin:/root/mod-workdir/modduo-new/host/sbin:/root/mod-workdir/modduo-new/host/usr/bin:/root/mod-workdir/modduo-new/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin" PATH="/root/mod-workdir/modduo-new/host/bin:/root/mod-workdir/modduo-new/host/sbin:/root/mod-workdir/modduo-new/host/usr/bin:/root/mod-workdir/modduo-new/host/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin" AR="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-ar" AS="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-as" LD="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-ld" NM="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-nm" CC="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-gcc" GCC="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-gcc" CPP="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-cpp" CXX="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-g++" FC="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-gfortran" RANLIB="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-ranlib" READELF="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-readelf" STRIP="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-strip" OBJCOPY="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-objcopy" OBJDUMP="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-objdump" AR_FOR_BUILD="/usr/bin/ar" AS_FOR_BUILD="/usr/bin/as" CC_FOR_BUILD="/usr/bin/gcc" GCC_FOR_BUILD="/usr/bin/gcc" CXX_FOR_BUILD="/usr/bin/g++" LD_FOR_BUILD="/usr/bin/ld" CPPFLAGS_FOR_BUILD="-I/root/mod-workdir/modduo-new/host/usr/include" CFLAGS_FOR_BUILD="-O2 -I/root/mod-workdir/modduo-new/host/usr/include" CXXFLAGS_FOR_BUILD="-O2 -I/root/mod-workdir/modduo-new/host/usr/include" LDFLAGS_FOR_BUILD="-L/root/mod-workdir/modduo-new/host/lib -L/root/mod-workdir/modduo-new/host/usr/lib -Wl,-rpath,/root/mod-workdir/modduo-new/host/usr/lib" FCFLAGS_FOR_BUILD="" DEFAULT_ASSEMBLER="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-as" DEFAULT_LINKER="/root/mod-workdir/modduo-new/host/usr/bin/arm-modaudio-linux-gnueabihf-ld" CPPFLAGS="-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CFLAGS="-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -O3 " CXXFLAGS="-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -O3 " LDFLAGS="-Wl,-O1 -Wl,--as-needed -Wl,--strip-all" FCFLAGS="" PKG_CONFIG="/root/mod-workdir/modduo-new/host/usr/bin/pkg-config" STAGING_DIR="/root/mod-workdir/modduo-new/host/usr/arm-buildroot-linux-gnueabihf/sysroot" INTLTOOL_PERL=/usr/bin/perl /usr/bin/make -j9 PREFIX=/usr NOOPT=true -C /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1
make[1]: Entering directory '/root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1'
/usr/bin/make all -C source
make[2]: Entering directory '/root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/source'
Compiling DistrhoPluginMain.cpp (LV2)
Compiling DistrhoPluginMaxGen.cpp
In file included from dpf/distrho/src/../src/DistrhoPluginChecks.h:24,
from dpf/distrho/src/../DistrhoPlugin.hpp:22,
from dpf/distrho/src/DistrhoPluginInternal.hpp:20,
from dpf/distrho/src/DistrhoPlugin.cpp:17,
from dpf/distrho/DistrhoPluginMain.cpp:17:
./DistrhoPluginInfo.h:29:36: error: token ";" is not valid in preprocessor expressions
29 | #define DISTRHO_PLUGIN_NUM_OUTPUTS ;
dpf/distrho/src/../src/DistrhoPluginChecks.h:134:32: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
134 | #if DISTRHO_PLUGIN_IS_SYNTH && DISTRHO_PLUGIN_NUM_OUTPUTS == 0
In file included from dpf/distrho/src/DistrhoPluginChecks.h:24,
from dpf/distrho/DistrhoPlugin.hpp:22,
from DistrhoPluginMaxGen.hpp:20,
from DistrhoPluginMaxGen.cpp:17:
dpf/distrho/src/DistrhoPluginChecks.h:134:32: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
./DistrhoPluginInfo.h:28:36: error: token ";" is not valid in preprocessor expressions
28 | #define DISTRHO_PLUGIN_NUM_INPUTS ;
dpf/distrho/src/DistrhoPluginInternal.hpp:149:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
149 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginInternal.hpp:193:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
193 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginInternal.hpp:246:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
246 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginInternal.hpp:412:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
412 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginInternal.hpp:432:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
432 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginInternal.hpp:555:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
555 | #if DISTRHO_PLUGIN_NUM_INPUTS+DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPlugin.cpp:46:8: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
dpf/distrho/src/DistrhoPluginLV2.cpp:94:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
94 | #if DISTRHO_PLUGIN_NUM_INPUTS > 0
dpf/distrho/src/DistrhoPluginLV2.cpp:101:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
101 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginLV2.cpp:269:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
269 | #if DISTRHO_PLUGIN_NUM_INPUTS > 0
dpf/distrho/src/DistrhoPluginLV2.cpp:280:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
280 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginLV2.cpp:1117:8: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
1117 | #if DISTRHO_PLUGIN_NUM_INPUTS > 0
dpf/distrho/src/DistrhoPluginLV2.cpp:1122:8: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
1122 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/../DistrhoPluginUtils.hpp:78:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
78 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginLV2export.cpp:467:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
467 | #if DISTRHO_PLUGIN_NUM_INPUTS > 0
dpf/distrho/src/DistrhoPluginLV2export.cpp:563:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
563 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
dpf/distrho/src/DistrhoPluginLV2export.cpp:1198:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
1198 | #if DISTRHO_PLUGIN_NUM_INPUTS > 0
dpf/distrho/src/DistrhoPluginLV2export.cpp:1203:5: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
1203 | #if DISTRHO_PLUGIN_NUM_OUTPUTS > 0
In file included from DistrhoPluginMaxGen.cpp:19:
../plugin/gen_exported.cpp: In function 'void gen_exported::setparameter(CommonState*, long int, t_param, void*)':
../plugin/gen_exported.cpp:148:9: warning: unused variable 'self' [-Wunused-variable]
148 | State *self = (State *)cself;
../plugin/gen_exported.cpp: In function 'void gen_exported::getparameter(CommonState*, long int, t_param*)':
../plugin/gen_exported.cpp:158:9: warning: unused variable 'self' [-Wunused-variable]
158 | State *self = (State *)cself;
../plugin/gen_exported.cpp: In function 'void* gen_exported::create(t_param, long int)':
../plugin/gen_exported.cpp:233:13: warning: unused variable 'pi' [-Wunused-variable]
233 | ParamInfo *pi;
make[2]: *** [dpf/Makefile.plugins.mk:393: build/test/DistrhoPluginMaxGen.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
dpf/distrho/src/DistrhoPluginInternal.hpp: In constructor 'DISTRHO::Plugin::PrivateData::PrivateData()':
./DistrhoPluginInfo.h:28:36: error: expected primary-expression before ';' token
dpf/distrho/src/DistrhoPluginInternal.hpp:224:28: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_INPUTS'
224 | parameterOffset += DISTRHO_PLUGIN_NUM_INPUTS + DISTRHO_PLUGIN_NUM_OUTPUTS;
./DistrhoPluginInfo.h:29:36: error: expected primary-expression before ';' token
dpf/distrho/src/DistrhoPluginInternal.hpp:224:56: note: in expansion of macro 'DISTRHO_PLUGIN_NUM_OUTPUTS'
make[2]: *** [dpf/Makefile.plugins.mk:449: build/test/DistrhoPluginMain_LV2.cpp.o] Error 1
make[2]: Leaving directory '/root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/source'
make[1]: *** [Makefile:26: plugin] Error 2
make[1]: Leaving directory '/root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1'
make: *** [package/pkg-generic.mk:198: /root/mod-workdir/modduo-new/build/tmp8owi0uji-b236792fa2bd4c3173c7182afe3e358a77e58df1/.stamp_built] Error 2
Build completed successfully.
It seems there’s a problem on a line of code in DistrhoPluginMain.cpp… but i checked in GitHub - moddevices/mod-plugin-builder: MOD Plugin Builder and the ā€œ;ā€ after the #define is not there…
is there something i can do on my side?
thanks a lot
I did a test here and the MOD Cloud Builder works for me. Dwarf, Osx (Mojave), Chrome.
Just a strange thing, it add an underscore before the plugin’s name, i.e. ā€œvoltestā€ gives ā€œ_voltestā€ . No big deal…
I’m on duo
Hi guys, should I really thrash my DUO for good? I have been stuck since YEARS now… anything can be done?
thanks :pray:
What do you mean ā€œyearsā€? it’s been barely 3 weeks …
means years. I subscribed to this forum on Mar 8, '21. Because the system for compiling and uploading gen~ was having problems and failed to compile. Since that date I did not be able to compile and upload gen~ plugins on my duo (which was the only thing i was interested in :man_shrugging: )
any help would be appreciated!
thanks
…there really seems to be some issue that needs investigation, as according to @zwabo it does work,on Osx, with Chrome.
in my case, win 10 and firefox, it doesn’t.
would be cool if the issue could at least be pinpointed and communicated via @falkTX to the community.
please upload the generated code that triggers this error.
it is the first time someone reported this to us, the expectation was that the max-gen builder was working flawlessly…
maybe a new max version does things slightly different now and breaks the build?
anyhow need to check the generated files to be sure
Here a simple in-to-out patch compiled:
ā€œError 2 → No plugins found in bundleā€. log here: Gen~ to MOD, build system seems broken - #44 by fcana
thanks
I’m not home now, I’ll give a try with your files tomorrow night and let you know how it works on my system.
Your files don’t work with the Mod Cloud Builder on my system. Which Max/MSP version did you use ?My last builds ok were made with
version 8.2.2 (not the last one 8.6.2).
i was on latest 8.6.3… tried to step back to 8.2.2 and WORKS! so… problem is definitively on newer versions of max! thank you @zwabo finally i’m on the road again!
Glad to hear that !
Hem…the problem seems a little trickier… I tried with 8.6.2 and that version works for me too.
ok @zwabo … got it. the problem is the text file encoding :man_facepalming:
  • the first files i compiled (attached previously) were from a win pc, that saves text files with Windows CRLF end of line. NOT WORKING
  • then i tried with a mac compilation, that saves files in Unix LF end-of-line format. WORKS.
all tests done with latest Max 8.6.2. PC or MAC provides exactly the same .cpp .h files, except for line encoding. so, @falkTX, here is the issue.
In the meantime, it is always possible to take .cpp e .h files windows compiled and then just resave them with unix encoding LF.
Hi everyone,
I’m experimenting with exporting a gen~ patch from Max and compiling it for the MOD Duo using the MOD Cloud gen~ Plugin Builder.
I followed the instructions and exported the code from gen~, which produced:
gen_exported.cpp
gen_exported.h
I uploaded both files in the builder and filled the required fields (plugin name, uid, etc.).
However when I try to build, I get this error:
modduo.support: error returned from server 0 (phase Initializing…)
Earlier I also tried compiling directly using the first compiler tool inside Max, but that didn’t seem to work either.
So I’m wondering:
  • Is the gen~ plugin builder currently working reliably on the MOD Cloud?
  • Are there specific gen~ objects that are unsupported and could cause this error?
  • Is there a recommended workflow for exporting gen~ patches for MOD Duo?
If anyone here has successfully compiled a gen~ patch recently, I’d love to hear how you did it.
Thanks!
Hi, I just did a test with a simple gen patch, everything is fine for me (Max 8.6.2).
But I did it for a Dwarf, Maybe the issue is related to the Duo …I don’t have the option to test it for a Duo or DuoX.
Thanks for the info, have you tried flashing the module directly from Max?
