Freezer - freeze your tone forever
In case others encounter this issue to load the plugin and the Mod device
subsystem request failed on channel 0
scp: Connection closed
adding the -O option should helped:
scp -rp -O <path to hvcc-Freezer.lv2 folder> root@192.168.51.1:/root/.lv2
And about the plugin itself, I’m very much impressed ! I really enjoy it ! Any chance to get access to the Pd patch or will it remain closed source ?
Not a very original use case, but it works very very nicelly ! :wink:
I would love to add this to my MDX. Is my understanding correct that I need to SSH into my MDX and add the LV2 folder manually to the plugins folder inside the MDX?
Yes, that should do it
Worked perfectly, thanks :ok_hand:
installed mr.freeze for my mod duo, work very good and very funny to use it
How did you manage to do that? Please help me with my MOD DUO.
