I followed the update instructions, Mod is now http://192.168.51.1/?v=1.4.0.374, FootEx is V0.0.5, but still the FootEx is not recognized. I switched the combi off/on several times, no joy. What to do? Many thanks for suggestions.
I’m not sure which build 374 exactly contains, but it’s not RC2 or RC3.
A related issue was fixed RC2 (build 380), fixed some mods that were not recognizing the control chain devices - just like you reported.
Since your 374 build < 380, I suspect you might not have the fix.
Please update to RC3 and let us know if it works afterwards.
Here’s a link to make it easier for you:
Many thanks for your help!
Hi falkTX,
I installed http://192.168.51.1/?v=1.4.0.395-RC4, same situation, still no result.
What to do?
Many thanks!!
@sanderbos just an idea (sorry if you’ve already tried): did you check it with another cable, just in case it’s a simple cable fault?
I will try this @plutek, thanks for the suggestion, will keep you posted.
@sanderbos, we just released the RC5, can you try it please?
Also, do you know how to SSH the MOD?
I will do it this afternoon, keep you posted.
I don’t know how to SSH, but I can learn how to
Is there like a tutorial?
Many thanks!
Ok. If you have no luck with the update we go to the next level.
@ricardocrudo
I upgraded the Mod to http://192.168.51.1/?v=1.4.3.487
I followed all the suggestions in Footswitch extension not recognized
Followed http://wiki.moddevices.com/wiki/Control_Chain#How_to_upgrade_Control_Chain_devices mutiple times.
Still I have no connection to my Footswitch (still in version 0.0.5).
What can I do? Thanks for helping out.
@sanderbos What is your OS?
On the Mac: version 10.12.6 (16G29)
On the Mod: version 1.4.3.487
A post was split to a new topic: Arduino Shield doesn’t connect
This issue has been fixed. The problem was the cable.
