@spunktsch i dont mind at all just not home at the moment ? Would you like the input target and json file?
sure, that also works.
@spunktsch https://drive.google.com/drive/folders/1c2H9M7zCwadeyd3zFEGG3ozm4FQhCTkk?usp=sharing
hope this works!
There is a lot of help requests for this “FileNotFoundError”. Could it be possible to update the ypnb to assign the correct name to the folder?
I must say that at this point it is to dificult for me to use Aida X Model Trainer, it is made for programmer, not a average person. I’v spent small amount of time reamping and most time trying to go to the third step - still" [FileNotFoundError while training the model]
my solution to this was to record a stereo track. Essentially re-recording input.wav along with the resultant audio. I split them afterward in Audacity (takes a few seconds). But this resolved my alignment issues and my ESR went from ~0.99 down to reasonable ranges (~0.001)
There’s a pedalboard link for how I recorded here: Modelling: best practices & conventions - #20 by malfunction54
@malfunction54 what kind of sound were you capturing ? clean , dirty , high gain? because the best result i could get was 0.2 with a high gain amp ! had the dame same volume and no latency. looking forward to the future of this though ! just hope it doesn’t eat up a montrous amount of dsp on the dwarf!
So far, I’ve just done clean amp capture. I’ll be doing lightly driven and higher gain next. I’ll see if my technique holds up.
@malfunction54 great !please if you don’t mind keepin us updated!
Even then you have to use the “bugged” pynb to actually train a model, which is frustrating for non-tech persons to mess with the “-0” in the folder name, who is in charge of fixing that?
I am unsure of who is ultimately responsible for the cloud-based training app, but I think @spunktsch is somehow involved with the project. Is that correct?
yeah. It’s @madmaxwell and me. See here Aida dsp - aida-x
I’d also like to have a more accessible training with a dedicated frontend guiding you through the process.
But resources are pretty limited at the moment. We have our dayjobs and this became more of a passion project.
I am not fluent in colab stuff, but I noticed that in step 2
model_dir = f"/content/Automated-GuitarAmpModelling/Results/{file_name}_{config_file}-{skip_con}"
Where skip_con can be 0 or 1
While in step 3
model_dir = f"/content/Automated-GuitarAmpModelling/Results/{file_name}_{config_file}"
thanks @Zavorra do you mind posting the issues to github?
So @itskais and @madmaxwell can track the bugs down.
@spunktsch by any chance did you try the files i sent you?XD
i trained a clean sound from a Hot rod deville , that sounds exactly the same , woooww ![]()
BUT , the problem now is that the trainer does not works FILE NOT FOUND ERROR ,
i don’t know much about code to fix this,
can you help us please
now im trying a dirty “clean” sound of the same amp, but i have a couple of weeks that i stoped to work on it because nobody of the Aida X team answers ![]()
