CV Control "PANIC" for all SEQ
Good afternoon. I really love your products and use them constantly. Recently, the way they’re used has changed, and I noticed one detail: the PANIC button in the menu for programming controls via MIDI, footswitch, knobs. And CV control is completely unavailable, even though all other functions have CV. The problem is that if you use the device as a drum machine for a performance, for example, with a guitar, it’s important to also set the PANIC button to start from zero when pressing the sequencer start button. This isn’t currently possible, but I’d be very grateful if you could fix this for all types of sequencers. Sincerely, Sergey
Did you try this? Dm-seq Not sure if it does what you want, but Dave M, the creator is quite active and constantly improving his plugins. Maybe you could try ask him if you think it could be improved.
The DM-seq is so musically cool and has a panic button built in (DM-seq-II-megalomania-power would be absolutely insane!!! :wink: ).
I have described alternative/manual panic here:
Unfortunately, this does not work with the classic SEq8x8 because it has MIDI IN, and in the DM-seq version, the panic button does not work yet (((I hope they will solve this problem soon))
Sorry, but it seems I figured out the MIDI clock plugin, although I still don’t understand how it works. But the internal clockhost fixed everything, and now start and stop always begin from the zero position of all sequencers. Thank you!!!
