Can I install all the plugins available in the store on my DUO, even if I don’t use them?
Can this reduce performance and/or is there any limit to this?
you can install all of them yes, but that is also correct that things will run a bit slower.
not the realtime performance, but the initial bootup time and web gui load time too
After MOD platform reboot I had installed just everything, being afraid to lose access to plugin store once again. But later I had to remove a lot of beta plugins, as influence of amount of installed plugins on the web gui load time is really noticeable.
This (allguis) speeds up loading somewhat:
I did that too and for the same reason. The time to launch the MOD increased significantly when I installed all the plugins from the store.
