Sorry to bother you guys…
I got my Dwarf now -
but can´t establish a connection with the USB-cable
via http://moddwarf.local
…tried some, but need help
thx
thx
Is you computer running Windows, Mac or Linux?
MDW is connected via MOD-USB cable to the PC
Please adjust the USB-B mode as described here: Dwarf Device Settings - MOD Wiki
I already played with that…
its not establishing connection in any setting of the 3 settings whatsoever
Have you tried force installing the Windows Driver?
https://wiki.mod.audio/wiki/Troubleshooting_Windows_Connection
I tried - but Windows persists of “already having the best drivers”
…thats my list of avialable USB ports:
Aside of that, I checked Firewall settings for Browsers (though, running anyway) -
and tried it in all MOD System Behaviour Settings available each with
Firefox and Opera (both actual versions)
I replaced the USB cable … still nothing
What if you connect directly to the ip address? → http://192.168.51.1
https://192.168.51.1 same as http://moddwarf.local …
“server not found”
Can you check in the Device Manager if the USB device has been configured as a Network Interface?
When the driver is wrong, it is configured as a Serial Device. If that is the case, the solution is to remove the device and force adding it again, but manually specifying the Windows Driver we provide.
gut-feelings here, this might be the problem:
plugging-in the MDW via USB doesn´t makes the Deivice-Manager react/update-window
at all…
Concerning your previous comment:
I deinstalled all USB, reinstalled…
okay,
referring to my last comment - plugging in the USB cable/MDW won´t
change anything here, by meanings of adding the MDW via USB does update the
Device-Mangers content tree at all:
any ideas?
update!
…maybe it was the “original” calbe - now I got some information within the Device-Manager:
I localised the “USB-device” which I wasn´t able to replace the driver on, though…
DeviceManager
showing hidden devices…
gave me that:
right clicking on it, trying to install “MDW-Drivers”…again…
Something looks very weird @Kopplog
Is your Dwarf running normally?
If Windows is seeing it as a Storage Volume, it should be in Restore mode instead of normal operation.
exactly, @gianfranco. Any ideas how to get around that?
My knowledge on such issues are pretty limited…
thanks for sticking to it!
chris
but what is the status of the device itself?
Can you send a picture of the display while the device is on?
