there is a bug in the online tool where some sessions are never closed.
I restarted the service that handles this now, so it should work again momentarily.
Thanks a lot for fast reply. Sandbox is working!
In the meantime I also tried the USB live image. It is excellent! Works perfectly and I am now able to checkout plugins even before my dwarf arrives!
Thanks for your work, on sandbox AND usb image.
@falkTX is there any chance that you can look into the failed iso build and fix it ? An almost up to date version of the iso would be great to play around until my dwarf arrives.
I really tried to understand all that build process but to start from scratch this is to time consuming for me, even with a really good IT knowledge. (I,m just no dev
thanks in advance
Is this function down permanently or does it just need a nudge? ![]()
I wanted to check on the sequencer/drum machine plugin stuff
It still works, but the link on the first post was an outdated one.
We should now use https://try.mod.audio/
Do note this is the same shared instance for everybody. Also it resets every 24h
doesn’t work on my phone, tablet, nor laptop…
