Hi guys,
I could use some help building my list with options and pro/con arguments
I’m considering a PA or FRFR speaker to replace my classic 212 guitar cabinet.
Since the start of my Dwarf era I’m convinced digital is the way for me and since AIDA-X the pro arguments outweigh my cons 5 to 1.
I already downsized my amp to a pedal sized amp and now I’m looking to replace my amp + passive cab with an advice speaker ¶ speaker.
I want to take full advantage of digital amps + cab IR’s and use a multifunctional setup for both metal and my solo guitar+vocal gig. The Dwarf has all that, all it needs is flat amplification and a speaker to let it be heard ![]()
such an active speaker could both act as cab at rehearsal (or small venue) or as monitor where helpful
I would prefer 2 inputs
… as the unit can also be used for other small party use or in a acoustic setup where somebody can fiddle with volume of guitar and vocal separately without touching my Dwarf ![]()
It’s not a complete showstopper though.
budget €400 - €600 ish
Size: was hoping to go for 10" or 12"
Being able to be audible as rhythm guitarist in a heavy rock/ Heavy Metal band is the plan. no need for boosted solo’s etc though. I’m hoping to stay away from buying a pair; one single speaker would be nice.
brand/types I’m considering
15" seems over the top for me
rather weighing 15 à 16kg than 20kg is a plus. smaller size versus bigger size is also neat.
Remember, I’m not PA’in a full band, I’m replacing my cab
- Alto (Cheap multi use units)
- Headrush 112 (same producer as Alto)
- RCF (a bit more expensive, a bit better I believe but only one input. that negates the optino to also use it as extra vocal innput in the rehearsal room, where it’s sometimes hard to hear myself without feedback))
- db technologies
I’ve did a bit of research on past topics here; read some helpful testimonials by regulars like @unbracketed etc.
*** Any of you guys using a PA/FRFR speaker in live situations instead of a classic guitar cab?**
*** Which option do YOU think I should consider?**
*** Any good/bad experiences or well voiced arguments concerning my current list of brand/options?**
