This is a very annoying bug and I don´t know if it´s happening with other plug-ins.
Description
Guitarix GXSupersonic Version 35.0-3
Can´t save, rename nor delete preset from the user preset list.
How to reproduce
Create a new user preset.
Save as “whatever”
Change the parameters
Save it
Change to another user preset
Select the “Whatever” user preset to verify that the parameters were not saved.
Try to rename it to verify that it is not possible.
Try to delete it to verify that it is not possible.
Exit the plug-in settings
Reload the GUI (Browser)
Enter the plug-in settings to verify that the parameters were actually saved and now you can rename and delete the “whatever” user preset but not if you change it again.
Expected/suggested solution
Be able to save, rename changed user presets and delete unwanted user presets without the need to reload the GUI (browser).
Additional information
release: Unit: MOD Duo (NAND Version) Build Date: 2022 Jun 07 19:50:59 OS Version: 1.11.6.2907
Kernel info: Machine: armv7l Release: 5.10.33-rt37-modduo Version:#2 SMP PREEMPT_RT Tue Jun 7 19:50:05 UTC 2022
Operating system: (Windows)
System version: (Windows 10)
Chrome Browser Versão 102.0.5005.63 (Versão oficial) 64 bits
The short story is that although the settings are being saved, the GUI will only reflect that if the user closes the plugin settings and refresh the browser.
And yes… same behavior with other plugins.
So immediately after saving the preset if you try to swap around between presets it doesn’t reflect it? And the same happens with all plugins?
If that is the case, it is exactly what I couldn’t replicate.
if you mean that saving presets on 1 instance does not right away show that same new content on another instance of the same plugin, this is a known limitation.
saving and editing preset details from the same instance you are using should work though.
or is this happening for you even when using a single instance of the plugin?
I don’t know If It happens with all plugins but It happens with at least one other plugin in the same pedalboard so I assumed that other plugins would show the same behavior.
I will create a new pedalboard to see what happens.
I recorded a short video to better explain the bug.
Please don´t mind my english!!! I has been a long time since I last spoke in english. https://youtu.be/Xb_EP-3qdZU
No worries with the english. It’s not that rusty
Thank you a lot for the video! It helps to better understand.
I’m not sure, but I believe that this may be some issue with the cache of the browser. Does the same happen if you use an incognito session on the browser?
I just tried to reproduce this, but I am unable to.
Used a Duo too, though in 1.12-RC2 instead of 1.11, but shouldn’t matter for this case.
Both in Firefox and Chrome presets are working as intended, so there is something else going on…
I dont know what to possibly try though, my only guess is some other plugin in the pedalboard messing with global state.
I can replicate what Rogerio is experiencing.
I am on a Mojave mac 10.14.4 with
Opera 88.0.4412.40 (current) and Safari Version 12.1 (14607.1.40.1.4)
both in normal and private browser sessions.
My Mod Duo is a NAND one http://modduo.local/?v=1.12.0.2910-RC2.
Like Rogerio, I tested this with the Gain 2x2 plugin with the help of the
TAP Pink/Fractal Noise plugin( -20dB output) and the X42 Level Meter.
I didn’t connect the gain plugin to the outputs on the right of the GUI because that was not necessary for this test.
In my case I made entries in the 2x2 Gain plugin as follows:
A: +4dB => Level Meter reading -16dBFS
B: +5dB => Level Meter reading -15dBFS
C: 0dB => Level Meter reading -20dB
If you switch between list entries, the level meter shows the right value accordingly.
I then selected entry A (current gain value +4dB) and altered it to +5dB.
Then I hit save. I expected the list entry A to be altered.
Other preset list entryies that are not saved anew are all perfectly okay (B and C) showing correct values.
If I then select preset A the gain value reads +4dB, also Level Meter reading -16dBFS
After a browser refresh the GUI works as expected with the new value of +5dB for list entry A.
One thing I can assure is that this is a very consistent behavior (bug) and very time consuming for the user because one are never really sure of the changed settings.
I keep re-entering the settings window to verify if things are accordingly to what I want and think twice before I change anything.
I wonder if others don’t have this issue, didn´t notice yet or simply don´t care about.
