Audio file player
You need to download it from the plugin store but the store for now is down due to the insolvency of the company.
See it here!
:disappointed_relieved:
Let’s wait. I have same situation here.
It should be in “Utility” plugin tab.
If it is not present, you have the following options;
  1. wait for cloud to be restored, it is down currently, refer to the following topic to understand the chances: MOD Insolvency and Reboot - #283 by danielrm - News - MOD Audio Forum
  2. ask some dwarf owner to share plugin folder extracted via SSH and install plugin via SSH file upload to your device
    Required folder is carla-files.lv2, it contains both midi and audio file players in one bundle, as far as I know. On MOD device it is located/should be located in /root/.lv2/carla-files.lv2
  3. same as 2, but that other dwarf owner shares backup of his box, and you get this lv2 plugin folder from the user.tar full backup archive.
If backup is taken from box with a lot of fresh plugins, and your dwarf is basically empty, it might make sense to just restore full backup and rewrite whole dwarf content, instead of dealing with each plugin alone via ssh.
Here is a topic where something like that is discussed:
  1. Unfortunately, at this point only shared plugin archive is mine, and it is for Mod Duo X, however, there is an opinion that these plugins might work on Dwarf. You may try getting carla-files.lv2 from my archive in this thread
  2. I can try building this particular plugin for you overnight (seems like I was able to do that for MDX), but you still will have to upload it via SSH anyway as well.
  3. If you are hardcore IT enthusiast and have a linux somewhere near you, you can try building plugins on your own with GitHub - mod-audio/mod-plugin-builder: MOD Plugin Builder · GitHub
Thanks.
I’m new to the fellowship. I just discovered the forum and the situation of the company.
Wait and see…
Is it intentional / for a technical reason that one cannot bind the file selection to a device knob etc.?
not intentional, but a technical limitation.
explained in UI - User-Preset Assignment kinda fails + Improvement suggestion - #19 by falkTX
Any plans of adding rewind to the player?
@Clervaux @falkTX
I have the same behavior on my dwarf.
Completely randomly some files don’t play from the beginning and sometimes they don’t play at all.
A workaround that works to always start the files the correct way is to change pedalboard.
As soon as you load the pedalboard that contains the player (I use three in the same pedalboard) everything works correctly.
But after playing the files in the player(s) the problem can recur.
Also i noticed that using “loop” the problem never occurs.
Unfortunately i can’t use the “loop” switch because i only need one playback.
I specify that the “host sync” switch is always in off
Hello, sorry if i’m off topic, I have loops loaded on file player,save it as a user board, it plays, but how can i change the file currently playing to another file from the mod dwarf without a pc or the GUI ??
Help appreciated. newbie
The best way to do it is to save a plugin preset with each single file and then assign one of the controls of your MOD Dwarf (either a Footswitch or a Knob) to select the presets of the plugin.
I’m using plugin in RPi4 Modep virtual pedalbord. I’ve made some pressets in preeset window. But when I try to assign Midi command to switch pressets it says that Midi command could not be assignet for that. Is there any feature to fix it?
I can also generate standart keybord commands for this purpose bthw (from m-vave choclatte plus).
Thank you for any help!
can someone add the functionality for updating the files seen by the plugin?
I usually add a recorder at the end of the signal chain to record a take and an audio player to listen, but I have to remove and reinsert the audio file plugin to be able to select the new recording. It would be great if we could have a trigger to refresh the file list.
Thanks
If you reload the web page maybe ?
Or reload the pedalboard ?
I don’t remember if reloading the webpage is enough, while reloading the pedalboard will certainly solve the issue.
But a nice “scan” button on the plugin to force the reload of the list of available audio files, would surely be better :smiling_face:
Reloading the page is enough.
