Audio File player: preset or file selection
I love the audio player for practice.
Tomorrow, our drummer is absent so we’ll practice with backing tracks for drums.
Ideal moment for the Dwarf to prove himself.
I couldn’t find how to assign either presets or files itself to a knob so I can roll through my available drumtracks.
So if there is no way to do that, that’s a feature request:
ability to cycle through files/presets on the audio player
(I did manage to make different snapshots with a different file loaded though but that needs some foot and handwork :smiley:
You can navigate through preset with a Mod Duo or a Mod Duo X because it has two endless knob. But I don’t know if Dwarf knobs can do that.
But you should be able to assign preset navigation to a footswitch. But only one footswitch can be assignated so you will be able to navigate through preset in only one way.
I want to revive this topic because I just discovered it and I’m surprised it had so little attention. Indeed, having the possibility to browse the audio file list with an endless knob in the device is an essential feature. Without it, it makes the plugin usable almost only in the Web UI.
Is there a technical problem that prevents the “Audio File” parameter from being assignable ?
I’m waiting for this feature since this plugin exist. I don’t use it because it can be used only with a web UI or if you’ve done your preset before.
