That we acknowledge the lack, but it’s not yet moving.
@rogeriocouto it sounds super cool and really close to the original!
I think for now I will need to create some “bin” to drop all of these pedalboards and eventually then find a way to showcase them properly. Optimally it will go to the MOD Audio website
That would be a “perfect bin” and save me some “monkey work”. So then when we want to accommodate that somewhere we will just go there. A bit like the Content Exchange thread.
I’m trying to replicate the Sound-On_sound effect used by David Gilmour on several occasions but i need your help. The effect is for simulating long keyboard chords
as a background to the Intro solo in Shine on you crazy diamond
even in the absence of a keyboard.
First used in Meltdown Live 2001/2002 (acoustic event), he strums with volume down, then smoothly raises the volume up. This way, there is no attack on the note, it’s all just smooth sustain.
There are two effect lines, line A for solo and line B for Sound-On-Sound effects,
it consists of a Roland SDD-3000 Digital Delay set at 1500ms with long feedback.
The trick is the expression pedal placed between the two lines (usually after
the input compressor) which functions as an A/B switch.
Dwarf doesn’t have (at the moment) an external volume pedal and so I’m trying to replicate the effect with a switch but without success. SwitchBox 1-2 does not allow the selection of the two channel with the momentary footswitch also adding a CV control doesn’t do the function. For sure there is something I’m doing wrong
Thanks for all…
I’ll post a picture of the pedalboard.
I wont post the real one because it’s not ready from the sound point of view. It’s my first one and I’m still searching for the better plugin for each part of the sound.
About the title of the discussion…
Have you already think about the specific artists section of the pedalboard site?
@jon
As promised, this is the Alpha version of the “Shine on You Crazy Diamond” with Sound-On-Sound effects. As said the best solution should be an external expression pedal but this version works…
Ooooo Yes, absolutelly… as soon as the sounds “sound” good and Gilmour like stile I’ll share this and maybe another one… about the sound demo …well I’ll try my best!!
