I’m looking (I need!!!) for a plugin where the inputs signal canbe moved between one output to the another.
Better if it can decrease one output while increasing the other.
Basically something like Stereo-XFade (by x42) plugin but opposite … one input to two outputs (or in stereo 2 inputs to 4 outputs).
I searched the entire Plugins library (even the betas) but couldn’t find anything.
No, or better it could be done with a simple volume plugin as I have done actually.
But the real use of this effects is to have a sort of A-to-B switch (one In, two Out) but with a continuos control (expression pedal). In this way you can send the input signal to one output while the other output is fade out (and the opposit).
Hope it is clear…
