I’m experimenting with things to use my MIDI expression pedal with.
One of the things that sounds good is when I turn up the room size on Shiro Verb. Playing with the room size all the way down and the ratio set at octave+ it plays an octave note up as I play (tracks great!). Then at the end of the phrase I like to make the shimmer just ring out… but when I assign the control to the expression pedal (EV-5 plugged into my SoftStep) it sounds like a zipper (or clipping) as I move the pedal.
Is this because MIDI is only 127 steps and the steps are too big for this control? Will the new expression pedals eliminate this issue?
or is this something within the plugin?
