Has anyone had any success (Or even investigated) getting
working as a MOD plugin?
I realise that it has a text file configuration, but wonder if this could be treated in a similar fashion to AIDA-X configurations ⦠edit on a PC, upload using the file manager and pick the one to use in the plugin config dialog.
From a quick look it looks quite doable to have on the MOD platform.
The config file usage could be turned into the GUI itself, where it only shows a text editor with an on/off switch, then changing the file would reload the plugin config.
