Hey all,
Thoucht you might want to know I used Zynthian’s build scripts to build a docker container that runs mod-ui.
So if you have any linux machine with docker, you can run mod-ui on it:
- Start jack on (example when user running jack 2 is user id 1000)
- To run it:
docker volume create --name=mod-ui-data
docker run -p 8888:8888 --user=1000 -v /dev/snd:/dev/snd:rw -v /dev/shm:/dev/shm:rw -v mod-ui-data:/home/moduser/mod-ui/data guysoft/mod-ui
- Connect to localhost:8888 to user mod-ui
Source code:
https://hub.docker.com/r/guysoft/mod-ui/
Also posted on Zynthian at:
