Seems like it would but I don’t want to be hasty-- one of the reviews said it is center positive, so I could plug it directly into the dwarf or duo x? Would greatly appreciate some advice, an older thread on this had me a bit confused.
It seems like yes. But I didn’t really understand how many mAh in 12V mode it pulls out. Anything less than 1.5mAh won’t work. I can tell from my own experiece.
They all make it so difficult to compare and figure out the actual specs as needed by a device! Here’s another one. No idea what the output polarity on this is, but I could use the right cable attachment to invert it… any sense of which may be more functional? I realize they’re both quite cheap in the grand scheme of things. Amazon.com: Volessence Portable Laptop Charger 12V/19V/19.5V/20V (TSA-Approved) 92.5Wh/25000mAh Universal Power Bank External Battery Backup for Laptop, Smartphone, Camera and More : Electronics
Yes. At the end of the day is almost worth ordering it and if it doesn’t work, return it. As long as you don’t feed more than 12V, you won’t break the MOD Dwaf.
I can tell you like 98% sure that this one works: XTPower PowerBank 15600mAh QC3-PA with Real-time Display LED Display & Power Supply - USB & 65W DC for Fast Charging - Compatible with Laptop & Smartphone : Amazon.de: Electronics & Photo
Btw I purchased the first battery I posted about (the talentcell one) and it’s amazing. Works great on both the Dwarf and Duo X, and I spent an hour on the Duo X running an intensive pedalboard with it today, with a soft step and little akai midi pad bus powered from the dwarf, and only one rung down on the battery. And it’s tiny. Excellent solution for portable power, as far as I can tell thus far.
