I have found that if I adjust the volume after each plugin with a “TinyGain Mono/Stereo” to about -10 dB it sounds much better.
Is it possible to add something like the “TinyGain Mono/Stereo” as a standard in every plugin to control the (between) volume?
This uses extra CPU power.
MOD Duo - Unexplained high CPU load depending on audio routing
